trailer 622 or Freedom
are there two different types of trailers:622 and or Freedom?
I don't own either (yet anyway) but my understanding from the long-timers on the forum is that the 622 is no longer manufactured and has been replaced by the smaller Freedom model. If I'm incorrect you'll know shortly.
Yes, you are correct
I believe they made the 622 from 2010-2014 it had two doors and was a little bigger than the freedom trailer that replaced it in 2015. The freedom trailer is a little less expensive than the 622 but from all accounts they are both really fine trailers. The 622 also came in matching colors, where they freedom is black with different accent stripe kits.
2014 RT-S Pearl White
The RT-622 trailer is the better of the two if you can find one.
Mike in KY
