Page 2 of 2 FirstFirst 12
Results 26 to 38 of 38
  1. #26
    Active Member rudym's Avatar
    Feb 2017
    Mobile, Al.
    Default for those without one
    Page 51 of the 2016 F3T/Ltd operator's manual shows the suspension pressure label, under your seat, that you should follow when setting the pressure you desire for your ride, with or without passenger and cargo.
    http://www.operatorsguides.brp.com/O...5C616648EN.pdf
    see paged 36 disappointing
  2. #27
    Mar 2016
    Texas
    Cool windshield
    I read somewhere that you shouldn't use a tire air hose, JC.... so that's a furphy as long as you use common sense to avoid any over inflate?
    Pete
    What windshield do you have on your Spyder?
  3. #28
    Jun 2016
    Harrington, Australia
    Quote Originally Posted by JoDot View Post
    It's a 25" F4 screen, JoDot......... p.s. I only saw this question quite by accident. You would be much better off sending a PM for a specific question like this to any forum members. It is impractical to read every comment in every thread just in case one mentions you. Besides, this is what is called a "hijack" of someone else's thread and is considered poor form, for obvious reasons
    Pete
    2021 RT Limited
    HeliBars Handlebars
    Kenda Kanine rear.
  4. #29
    Feb 2017
    Sherman Oaks, CA
    I have an 2016 F3T and want to check pressure but can't find the valve?
  5. #30
    Jun 2016
    Quote Originally Posted by Supaagent View Post
    Remove your passenger seat, you can't miss it .
    Pete
    2021 RT Limited
    HeliBars Handlebars
    Kenda Kanine rear.
  6. #31
    Feb 2017
    Sherman Oaks, CA
    Pete
    Found it.thanks
  7. #32
    Feb 2016
    Québec Canada
    Default F3T REAR AIR SHOCK
    I add a compressor with automatic control. It adjusts for one or two passengers. Works well and is available at BRP
  8. #33
    Feb 2017
    Mobile, Al.
    Default owners manual 2016 F3T
  9. #34
    Jun 2016
    Quote Originally Posted by Mario View Post
    I thought about this, but never found the need, Mario. If you check your pressure once a week and top up, it all works very well, without another mechanical part to possibly break down. My manual one also adjusts for one or two passengers
    Pete
    2021 RT Limited
    HeliBars Handlebars
    Kenda Kanine rear.
  10. #35
    Active Member nealperkins's Avatar
    Feb 2017
    Fort Myers, FL
    After all this discussion I thought I'd better go check my pressure on my fairly new F3L...it was zero. Oops.
  11. #36
    Jun 2016
    Quote Originally Posted by nealperkins View Post
    The number of times I have heard this makes me think that there are very few techs who even know the manual air spring exists on the F3, Neal. Mine was zero at pickup even after asking them to set it for a 300lb rider. Was there any air in it when you first picked it up, or is this the very first time you have checked it?
    Pete
    2021 RT Limited
    HeliBars Handlebars
    Kenda Kanine rear.
  12. #37
    Jul 2011
    Cleveland, Ohio
    Quote Originally Posted by Buckskin View Post
    When adding air to the shock, is it best to use a hand pump of some kind or can one just use regular air line and give it a quick shot of air til you reach that proper pressure? At 200 lbs, what is recommended pressure and if adding a passenger about how much more to add?
    Buckskin
    I weigh 210 and use 30 lbs. with a hand pump that includes the gauge so I know what I am putting in. Works fine when Two up.
    Chris
  13. #38
    Feb 2017
    Mobile, Al.
    Default what he said
    We keep 40 psi in our F3L, I use a progressive suspension hand pump. Just to note it's not an air shock. There is a shock and a separate air bag.
    yep and yup!
