Results 1 to 5 of 5
Thread: Oil light on
    Apr 2017
    Question Oil light on
    Just a question if someone may be able to shead some light. Just did a oil change on a new to me 2008 GS. Light went out when I started it up, went for a short ride, maybe 1/2 an hour. Then the oil light came on. checked level again and oil on dip stick is up where it should be. don't see any oil leaks. Any ideas?
    Nov 2015
    Chardon, OH
    Quote Originally Posted by sibbaldb View Post
    Well, the oil light indicates low oil PRESSURE. So, normal with the engine off. Not normal with the engine running.
    If you've got the light with the engine running, then the quickest thing you can do is pull the filter(s) and check for a collapsed filter. For some reason, that happens occasionally. One of the causes of that, that I've read about, is that the end plate of the filter separates on removal and stays inside the housing cap. if that isn't noticed and the new filter is installed, it damages it and causes the problem.
    Otherwise, if that all looks OK, then it could be a more serious internal issue or the sender - but the timing of it all suggests something related to the oil change. Good Luck. Tell us how you make out.
    Doug
    ”Freedom is not a loophole”
    Nov 2012
    North Las Vegas, NV
    The other thing is if you got the filter in backwards. The hole goes in.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Default All of the above
    but it is good to specify which clutch you have. The Se5 (auto) or the Sm5 (manual) as you may need to check both filters on the Se5. Oil light is the pressure and therefore either the sending unit, oil pump or the flow...have you ever had the oil screen cleaned in the oil tank..? this could also slow the flow back to the pump...
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Jul 2011
    Mitchell, Ontario, Canada
    The oil pressure light has nothing to do with the pressure in the SE5 HCM. It does not have a oil pressure sender and is only pressurised for a couple seconds during a shift. The oil light is engine pressure only.
