Driver back rest
What back rest should I buy?
I have the utopia and love it. Check em out, I think you would be impressed.
+1
It is easy to install, adjustable and matches my bike. I wouldn't go without one.
I have the BRP one and it's great, but Way to much money.
Neil
2020 Harley Davidson Tri Glide Ultra
2017 F3-T SE6 White / BRP Backrest / Nuvi 58 LM / Polaris Spring Spacers / CALSCI 22" Shield
Utopia here. easy install and fully adjustable for a fraction of the BRP plus adjustable bracket.
"If you can't be a good example, then you'll just have to be a horrible warning." Catherine Aird
Hi Bob, I Have The Brp One With Fixed Angle.can I Retro Fit The adjustable Bracket.
One thing ive found with rest is when im on rough road it kind off kicks you in the back as the bike rocks back and forth.i find myself moving off the rest a fair bit.our aussie roads are crap.
Stu
Yes you can add adjustability
Stu
You can definitely add the adjustability to your current seat. I was quite happy with the addition and I believe it was a $79 option from dealer. Install isn't too bad, three hands are helpful. Along with a paper clip to use to unzip the factory seat.
2014 RT-S Pearl White
ok thanks guys for reply.is that a brp part or after market.is there a part number or supplier i can buy from that you know..
cheers stu.
if you go utopia, ask about the 1" setback bracket. it made mine much better.
[joyce & irvin toms]
This is a BRP part
cheers stu.
There are two parts depending on the current seat you have.
https://can-am.brp.com/spyder/shop/a...sts-racks.html
Utopia! Color matched. Top quality. Back rest adjusts it's angle to your back, instead of visa versa like the BRP. Great people!!
Utopia! Color matched (by RDL) before going to the RDL seat it matched the stock seat. Agree the Utopia works great.
Dick Harding
Boise,ID
2011 Spyder RT SE5 Limited
Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming "Wow! What a Ride!
Large1 is online now Report Post
