Results 1 to 8 of 8
    Apr 2017
    North Central Florida
    Default 2011 RT. Brake and shifter NOT adjustable ??
    REALLY ?? On a machine that originally retailed for OVER $20,000 ???
    SERIOUSLY ??
    Adjustable pedal position...via an adjustable linkage.....that is.
    The salesman said YES.
    The service tech says NO.
    I suspect that the service dept. is right but I'm more than a little disappointed.
    Apr 2017
    Quote Originally Posted by Easy Rider View Post
    Update:
    While taking seemingly every piece of body work loose to take out some dead LED wiring
    I discovered that the shifter linkage IS adjustable; imagine that.
    Haven't looked at the brake side yet but I bet that it is too.
    Can't trust anybody anymore.
    I also found the tool kit that the service department said was missing; strapped right there to the underside of the seat.
    Yes; you can move the sifter on it's shaft...
    But you can't do that with the brake pedal...
    RE: Brake pedal. We installed floorboards on our 2011 RT. I felt that the brake pedal was then to close for safe emergency stops. We bought a bigger pedal and it came with the proper riser. It works for us.
    Active Member Large1's Avatar
    Dec 2016
    Boise ID
    I agree about the spacer I just added a 1 and 1/2 inch spacer with longer bolts and it worked out great.
    Dick Harding
    Boise,ID
    2011 Spyder RT SE5 Limited
    Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming "Wow! What a Ride!
    Large1 is online now Report Post
    Apr 2017
    Well with the one I have, the shifter linkage has the traditional adjustable linkage rod; you loosen two lock nuts and make the rod longer or shorter, allowing for smaller adjustments.
    Like others have mentioned, I have a larger brake pedal on order and will "shim" it up with spacers and longer bolts as needed.
    SoFlo
    Have a close look at the brake. The rod may be adjustable, but the pedal posistion may not be. Use care if you adjust the brake rod, you do not want to block the bleed hole as the brakes will drag or not release when hot.
    You might however be able to locate the pedals hard stop and change that, but I do not recall it being adjustable.
    Default Agree...
    On many (RS 2012) the shifter had the toe section adjustable as well as the lever to the shaft. Unfortunately the brake was fixed. As you can see from other posts there are options. In my case I made up new pedals...
    20160125_091712.jpg we also have a manual park brake pedal so I did that one as well after banging up my shin a few time....
    ​2012 RS sm5
