Results 1 to 7 of 7
    Apr 2017
    Delaware
    Default Bluetooth Dongle volume
    Hello
    I just installed a bluetooth dongle on my 2016 RT Limited. the volume is very low in my helmet.
    how do you control the volume, I did what Sena recommended 2 tap on the google. It does raise the volume a little but my outside speaker are blasting? how do you cut off your bike speaker and only have your music in the helmet
    Thanks
    Patrick
    Jul 2011
    Mitchell, Ontario, Canada
    Two ways. Turn the volume down to almost mute. That way you can listen to the external speaker when you want. Or you can go into settings and turn the external speakers off.
    2018 F3 LIMITED
    Very Active Member SPYD3R's Avatar
    Apr 2011
    GREENVILLE, SC
    Default PHONE
    i spent 3 years with low volume until i was told that it wasn't SCALA but my phone....
    i went into the phone SET-UP and corrected it, then i also down-loaded the app: VOLUME ACE (Free), and that was a great help....
    Dan P
    SPYD3R
    Apr 2017
    Delaware
    the volume of the bluetooth is not control by the volume of the bike ( handlebar)?
    Jul 2011
    Quote Originally Posted by ppatrick1090 View Post
    The output to the dongle from the radio is fixed. But can be muted. The volume is controlled by your headset.
    2018 F3 LIMITED
    May 2013
    Stanton, ca
    One thing to add. When you put the speakers in your helmet it is super important to have them as close to your ears as possible. That is what the foam pads are for.
    Yes the BT dongle is a fixed volume.
    Bob
    2011 RT-S SM5 - Black
    Apr 2017
    Delaware
    Thanks..
