Results 1 to 6 of 6
    Apr 2017
    Villanova, PA
    Default Body Panel Removal from RS
    I have a new 2016 RS and need to remove all of the body panels to install LED lights, a radio, and to place decals. There seems to be only a few hex head bolts on the panels, and I guess there are a lot of clips I don't see. I have a manual and shop book, but they only have exploded views but no instructions. Anyone have any tips as to the sequence to remove the panels, how to do it, and anything else that I need to know. Thanks.
    Default Here's what I do...
    Start with the mid panels (where your knees are). Then the front panels (pop the frunk lid to get the push pins) then the rear panels (you have push pins under the seat and torx under the splash panel) youy will have to disconnect the turn signals. Then on to the air dams. finally the splash guards (there are 10mm bolts under going to the frame. Finally the top plate and the tail piece. The frunk can be removed as a unit or just the lid...good luck take your time and keep the screws and pins with each panel...
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Apr 2017
    Wisconsin
    Default Check owners manual
    I have a 2012 RS-S my owners manual has pretty good instructions. Are you sure they don't have instructions in your owners manual for removing panels???
    If not maybe try down loading a 2012 RS-S owners manual.
    Active Member Huked's Avatar
    Mar 2017
    Watford City, North Dakota
    Quote Originally Posted by BernieB627 View Post
    if that is still not clear? You can look up things like changing the battery and such on YouTube most the jobs start by showing what panels need to come off and how. Several of the sway bar videos show hoe to remove the frunk. Just look through YouTube you will find a ton of help.
    2019 RTL
    Farkles
    BRP Comfort Seat.
    Foam Grips
    Lidlox
    BRP Passenger armrests
    Baja Ron Anti sway bar
    Lamonster's upgraded BRP vibration damper.
    2019 RTL , Asphalt Grey Metallic Dark
    Very Active Member JerryB's Avatar
    May 2014
    Beaverton, Oregon
    Hi Bernie,
    Re: need to remove all of the body panels
    Look here:
    Breakdown:
    http://www.spyderlovers.com/forums/s...pdated-Version
    Sway Bar Install:
    http://www.spyderlovers.com/forums/s...t=sway+install
    Changing the coolant:
    Oil Change Tips:
    Jerry Baumchen
    'I'll never forget what's her name.'
    'Things are more like they are now than they ever have been before.' Dwight Eisenhower
    2008 GS SE-5
    Dec 2008
    Syracuse, NY
    Nice job JerryB. To get my panels off my 2008, I just have to snap my fingers once, and click heels 3 x's.
