Page 1 of 5 12345 LastLast
Results 1 to 25 of 107
    Very Active Member OverHillAndDale's Avatar
    Sep 2014
    United States
    Default Magic Mirror Mounts
    I've popped my mirrors out of those ridiculous pop-on mounts for the last time.
    I'm seconding the recommendations people have made on behalf of the Magic Mirror Mounts. Took about 20 minutes to install (mainly because my workbench is a mess), and the mirrors are held in place by amazingly powerful magnets.
    If you find yourself having to remove your mirrors regularly to work on the bike, these will make that task MUCH easier to perform. I've always feared that I was going to break something removing the mirrors, but these remove that fear.
    2020- RT Limited
    Chalk White, Can-Am rear passenger armrests, Comfort Seat, Grip puppies, RAM Cup Holders, Providence RAM Mount
    FOBO2 TPMS
    Aluma MCTXL trailer
    BRP hitch
    Big Bike Parts wiring harness
    Permanent Smile!!!
    Pretty neat; aren't they?
    How'd you like wrestling with them, while getting them separated with each other?
    I needed a nap, after I got done with it!
    Member hschuchman's Avatar
    Aug 2016
    Maryland
    Cool
    I ordered mine!!
    You will not be disappointed!
    United States
    We still have a few left for sale before we reorder. They are awesome!!
    http://dochumphreys.wixsite.com/roadster/products
    Very Active Member irvin48's Avatar
    May 2016
    mt morris il
    Quote Originally Posted by Doc Humphreys View Post
    be sure to watch docs install video or russells original. best bang [literally]
    for your buck farkle yet !!!!!
    [joyce & irvin toms]
    Sep 2014
    United States
    When I was wrestling, I accidentally had two magnets come in contact with each other AFTER I'd removed the white washer that had been separating them. WOW!. I tore a fingernail and ended up using two screwdrivers, one in each hole, to pull them apart.
    So, I set down the magnet and it pulled over a knife I had on the workbench, so I had to separate the magnet from the knife.
    So, buyer beware! Great product, but if you're not used to working with powerful magnets you need to assume that EVERYTHING might be magnetic, and avoid anything coming in contact with the magnets. Having two of them come in contact with each other is the worse case.
    2020- RT Limited
    FOBO2 TPMS
    Aluma MCTXL trailer
    BRP hitch
    Permanent Smile!!!
    Mar 2013
    Marion, Arkansas
    Quote Originally Posted by OverHillAndDale View Post
    I had the same thing to me when I was installing my Magic Mirrors. What happened to me was that when trying to separate the 2 magnets, they slammed back together and wound up pinching some skin on one of my fingers and caused it to bleed and create a blood blister. Its still sore this morning. Oh the pain we go through to add farkles to our bikes.
    2008 Triumph Rocket (SOLD)
    2002 Honda VTX 1800 C ( SOLD)
    Feb 2016
    Don't try to pull them apart, slide them apart. Also, try to be ready to install the magnet so that you don't have to set it down on anything. Any minuscule bit of magnetic material will become a permanent addition to your installation in the form of grit.
    2020 RT Limited , Marsala Red
    SpyderLovers Sponsor merlot's Avatar
    May 2015
    Tasmania
    Great advice jet
    i use a cymbals action and hold the single magnet high and away
    i then put the remaining pack into my opposite pocket before building the screws and washers assembly and fitting immediately to the bike
    i separate 600 of these at a sitting and have only been bitten once....well,would you believe twice?
    russ
    Apr 2015
    Brockville ONT
    I agree this is a great product.I was always worried i would break somthing when removing or reinstalling the mirrors.Install was very easy.
    Bill
    2018 RT Anniversary , Brake pedal extended
    May 2016
    mt morris il
    just dont lean on them while cleaning your windshield. and thats
    why i put on the tethers ! learning curve accelerated !!
    Oct 2011
    Jacksonville,Ar
    Default Mirror
    I have had mine on for about two weeks.
    I was wonder what would happen if I hit a big pot hole if they would stay on.
    well I hit one coming to Spyderfest the mirrors stayed on.
    15 rt , yes Black
    Invalid Emails
    Mar 2017
    Cloudcroft
    Mine came yesterday. Mailbox is on a community rack serviced by our local PO folks. Had to yank to get the package out of the iron box so I've already had a warmup witout even opening the shipping bag!
    Aug 2012
    Central Coast, CA
    I installed mine with the "assistance" of my granddaughters. Russell quite thoughtfully separated the magnets with plastic washers, but unfortunately, one of my granddaughters didn't listen too closely and started playing with the pre-separated magnets. Pop went the magnets. Stuck together with no separator. Now, that was a bugger. I got it, but it wasn't fun. Fortunately, no finger pinch for my granddaughter. Otherwise the installation was a piece 'o cake.
    Great product! Way to go Russell!
    2020 RTL SE6
    Jul 2013
    Marietta, GA
    Installed mine.. very nice
    Great job Russell
    Invalid Emails
    Mar 2017
    Cloudcroft
    Ditto the install, went off without a hitch but I attribute that to hearing over and over about being careful with the magnets. I found that a slight twisting motion back and forth while pulling apart made the separation pretty easy. Worth the price IMO, plus I got the added benny of picking up a little Aussie lingo in the instructions!(««shrimp oc)
    Mar 2017
    Star, Idaho
    Received mine yesterday, going to install when I get time. I couldn't believe how these mirrors were designed to come off, so when I saw these I jumped on them.
    Active Member mcalva's Avatar
    Nov 2016
    Viladecans, Barcelona, Catalonia, Spain
    I received yesterday the mounts. I live in a four-floors building with an elevator and the postwoman's bag was stuck on the elevator walls and she could not take it off. I think the power will be enough to hold the mirrors.
    2018 F3 Ltd. , Black/Dark
    Nov 2016
    SW Michigan
    Default Another Happy Customer for Magic Mirror Mounts
    Received my Magic Mirror Mounts today. I watched the You Tube video's on installation and the installation went flawless. I had no issues with the magnets. Before, I dreaded taking off the mirrors in fear of braking something, now it is so easy. I can say this now, but I would have paid 2X or 3X the price, as this innovation is well worth it. The wait was also well worth it. It took about 20 days to arrive to Michigan.
    Thank you, Jeff
    Invalid Emails
    Nov 2014
    USA, FL, Venice
    I have lost track of how many times I have demonstrated the magnets at SpyderFest. Haven't met anyone yet who wasn't impressed.
    Active Member ricford's Avatar
    Jun 2015
    Calhoun, La
    Based on MY experience, expect 18 days from order to delivery. Your mileage may vary. Can't wait to install them but just got back from Spyderfest 2017 in Springfield. Maybe take a couple of non Spyder days off.
    Very Active Member Y Rider's Avatar
    Oct 2010
    Springfield, MO
    Hope mine shows up in my mailbox soon. It's been 19 days so hopefully will arrive this week. Mine was shipped on April 10th. Tracking says it arrived in Chicago on the 20th.
    MODS: Elka Shocks, ESI RT HMT Brake Light, ESI RT Brightsides, ESI Fender TIPS, ESI RIPS, ESI RT Day Runners, Grip Puppies
    AmerSeal Sealant, KewlMetal Kewlock, Scorpio I900 Security System, Stebel Nautilus air horn, KewlMetal Highway Brackets & ISO Wings
    Corbin seat, trunkrest & driver backrest, Capt.Jim's Belt Tensioner, SpyderPops LaBlock, Cat Shields, Bumpskid & Belt Guard
    Seal PUP Floorboards, BRP chrome, Ron's Anti-Sway Bar, Lamonster LED Head/Fog Lights & BRP Air Scoops
    2011 RTL , White
    Active Member wolphspyder's Avatar
    May 2013
    Elgin, Texas
    Picked up a set of Magic Mirror Mounts from Lamont while my wife and I were at Spyderfest....I installed these mighty magnets today, after we returned home, and it only took about 15 minutes to install them on "My Serenity" wow....Magic Mirror Mounts is going to save a lot of wear and tear at service and farkle time.... I really like them ........
    " My Serenity "......2017 Spyder F3T....Silver Gray in color,Red dragon on Celtic cross on frunk,Blade wheels,Spyderpops bumpskid,LED headlights and foglights,Lamonster heim joints,Lamonster powerpoint,F3 Spyder cuff, Lidlocks helmet lock,Lamonster air pack,Ron-jon sway bar,Sara Clark painted thin blue line and Sheriffs badge, Spyderpops LED strobe brake and rear turn signal lights, Lamonster gas cap, bluetooth.
    2017 F3T , silver
    Active Member Buckeye Chuck 54's Avatar
    Jun 2015
    Zanesville Ohio
    Default Lucky
    I ordered mine April 2nd got a message they were shipped on the 10th.
    May 1st and still no M&M's. I wrote Russell and was told the problem is on my end.
    My bad, should have ordered from somewhere else.
    Never again.
    B.S.
    Buckeye
