Page 2 of 2 FirstFirst 12
Results 26 to 36 of 36
  1. #26
    Active Member hillbillywhisperer's Avatar
    Dec 2016
    Florida
    I went with the Original Grip Buddies. Easy peazy and I love em.
  2. #27
    Active Member Av8er's Avatar
    Sep 2016
    Mobile
    I had these on my vstrom and loved them. Y'all just reminded me I need to order some more for my Spyder. Can you still feel the heated grips after installation?
  3. #28
    Active Member nealperkins's Avatar
    Feb 2017
    Fort Myers, FL
    I got them on using a combo of the above plus a long, thin screw driver to 'lift' the foam a bit while pulling the grip with needle nose pliers. Whew! I'm glad it was worth it!
    Thanks for the suggestions!
  4. #29
    Active Member cheska's Avatar
    Apr 2013
    Vancouver Is. BC /Arizona
    Default Heat
    Yes you can still feel the heated grips even on low Bob
    900 Ryker Wifes
  5. #30
    Active Member Cleg's Avatar
    Apr 2012
    Queensbury, NY
    Default Easy install
    Quote Originally Posted by nealperkins View Post
    Foam grips seemed like a good idea for my F3T...until I tried to install them. The instructions seem to indicate they would slip on but getting them over the raised edge seems impossible. Maybe there's a 'trick' to make it happen?
    Thanks!
    Spray isopropyl alcohol on the handlebars and the foam grips slip right on. The alcohol dries quickly and residue or issues....
  6. #31
    Bossier LoUiSiAna
    Quote Originally Posted by oldman55 View Post
    +1 hand sanitizer worked for me. Use a very liberal amount, never to much just not enough. Don't be afraid to slop so much on the inside of them that they are dripping wet.
    I pinched on side of my grips closed & then almost filled to top with dollar store hand sanitizer, then put som on the grips themselves. Made my fingers lil slippery but I got both mine on over my lidlox & the bar end cap on both sides. Left to dry & all is good. Fyi mine are the foam grips from Tricled (thank you Cindy!)Installed at my hotel.
  7. #32
    Dec 2014
    S.E. Michigan
    Default Windex
    I used Windex. Didn't think it would work, but it did!
    ~Sandee~
    ~Sandee~
    2016 RT-L (Purchased used in February 2018)
    RT Dash Mount (from JT's Spyder Store)
    Kuryakin Trident Highway Pegs
    Hopnel Pouch
    Magic Mirrors
    Spyderpops Foam Handgrips
    Iron Butt #35273
    Girls on Spyders #2779
  8. #33
    Very Active Member 2Paw's Avatar
    Feb 2013
    USA, Texas, Mckinney
    Quote Originally Posted by hillbillywhisperer View Post
    Which part# did you use? I only see them for RS only and the Outlander ATV.
    Ed
    They told me not to give up on my dreams, so I went back to sleep.
    Champagne 2017 RTS SE6
    Quantum Blue 2012 RTS-SE5 "Bluebell, Bell for short" - Traded 09/2017
  9. #34
    Active Member Gator37's Avatar
    Jun 2013
    Soap Lake, WA
    Installed a set of foam grips yesterday without any addition of slickem. It was a tight fit and hard to gt over the raised end of grip but is possible. They feel good too now that they are on.
    American by Birth, Southern by the Grace of GOD.
    The Older I get the Better I Was.
  10. #35
    Invalid Emails
    Feb 2016
    Dublin, OH
    These things must come in sizes! These are not 'sliding' anywhere. Getting them over the rigid end cap would be a major accomplishment. I was thinking maybe you guys were using a hair dryer or some such?
    Neal , did you get the foam grips from us?
    If you do, it only comes in 1 size. and ours always slide in about 1/2 way easily using hand sanitizer.
    Once it slide about 1/2 then we have to twist and muscle-it a bit to get it all the way in.
  11. #36
    Active Member wvedec's Avatar
    Nov 2016
    Ponchatoula, LA
    Default Hand Sanitizer
    Hand sanitizer worked great!!!
