Page 2 of 2 FirstFirst 12
Results 26 to 36 of 36
  1. #26
    Dec 2016
    Florida
    I went with the Original Grip Buddies. Easy peazy and I love em.
  2. #27
    Sep 2016
    Mobile
    I had these on my vstrom and loved them. Y'all just reminded me I need to order some more for my Spyder. Can you still feel the heated grips after installation?
  3. #28
    Active Member nealperkins's Avatar
    Feb 2017
    Fort Myers, FL
    I got them on using a combo of the above plus a long, thin screw driver to 'lift' the foam a bit while pulling the grip with needle nose pliers. Whew! I'm glad it was worth it!
    Thanks for the suggestions!
  4. #29
    Apr 2013
    Vancouver Is. BC /Arizona
    Default Heat
    Yes you can still feel the heated grips even on low Bob
  5. #30
    Active Member Cleg's Avatar
    Apr 2012
    Queensbury, NY
    Default Easy install
    Quote Originally Posted by nealperkins View Post
    Foam grips seemed like a good idea for my F3T...until I tried to install them. The instructions seem to indicate they would slip on but getting them over the raised edge seems impossible. Maybe there's a 'trick' to make it happen?
    Thanks!
    Spray isopropyl alcohol on the handlebars and the foam grips slip right on. The alcohol dries quickly and residue or issues....
  6. #31
    Bossier LoUiSiAna
    Quote Originally Posted by oldman55 View Post
    +1 hand sanitizer worked for me. Use a very liberal amount, never to much just not enough. Don't be afraid to slop so much on the inside of them that they are dripping wet.
    I pinched on side of my grips closed & then almost filled to top with dollar store hand sanitizer, then put som on the grips themselves. Made my fingers lil slippery but I got both mine on over my lidlox & the bar end cap on both sides. Left to dry & all is good. Fyi mine are the foam grips from Tricled (thank you Cindy!)Installed at my hotel.
  7. #32
    Dec 2014
    S.E. Michigan
    Default Windex
    I used Windex. Didn't think it would work, but it did!
    ~Sandee~
    ~Sandee~
    2016 RT-L (Purchased used in February 2018)
    RT Dash Mount (from JT's Spyder Store)
    Kuryakin Trident Highway Pegs
    Hopnel Pouch
    Magic Mirrors
    Spyderpops Foam Handgrips
    Iron Butt #35273
    Girls on Spyders #2779
  8. #33
    Very Active Member 2Paw's Avatar
    Feb 2013
    USA, Texas, Mckinney
    Quote Originally Posted by hillbillywhisperer View Post
    Which part# did you use? I only see them for RS only and the Outlander ATV.
    Ed
    They told me not to give up on my dreams, so I went back to sleep.
    Champagne 2017 RTS SE6
    Quantum Blue 2012 RTS-SE5 "Bluebell, Bell for short" - Traded 09/2017
  9. #34
    Jun 2013
    Soap Lake, WA
    Installed a set of foam grips yesterday without any addition of slickem. It was a tight fit and hard to gt over the raised end of grip but is possible. They feel good too now that they are on.
  10. #35
    Invalid Emails
    Feb 2016
    Dublin, OH
    These things must come in sizes! These are not 'sliding' anywhere. Getting them over the rigid end cap would be a major accomplishment. I was thinking maybe you guys were using a hair dryer or some such?
    Neal , did you get the foam grips from us?
    If you do, it only comes in 1 size. and ours always slide in about 1/2 way easily using hand sanitizer.
    Once it slide about 1/2 then we have to twist and muscle-it a bit to get it all the way in.
  11. #36
    Nov 2016
    Ponchatoula, LA
    Default Hand Sanitizer
    Hand sanitizer worked great!!!
