DESS module location,
I got almost every panel and dash apart and I cannot find the Dess Module, I need to make the wire from IGN switch to the module get more slack. it goes under the dash and into the very forward section of the top frame rectangular tube.
Thanks for that, back to the hunt. I must have googled this 10 different ways. By adding the second OEM 1" riser caused the dess wire to be too tight. If I can't get some slack I'll have to scrap this idea and go with cutting the bars and using Rivco type risers.
May I suggest getting a digital copy of the service manual. $25 is a good investment.
