Trunk won't close 2016 RT limited
Hi
I am a new spyder rider.. Just bought a 2016 RT Limited.
This morning i install lights on each side of the bags
I remove the long piece under the trunk to attached the wires. after putting back together the trunk won't latch? the plastic piece seem to fit correctly, put the screw back It won't close?? Am I missing something? with out that plastic trunk close fine??
any suggestion?
Patrick
More than likely you missed getting the tab back in the right spot which is located directly above the key hole or directly under the label inside the trunk which says 20 lbs limit. When putting that long piece of panel back on folks sometimes miss getting the tab back into the slot. this will cause the trunk lid to not close. If it is not that then I don't know.
Gary
States visited by Bike
Gary
Exact same thing happened to me. It was the tab, and it's not readily visible. Unfortunately, getting back into its proper place will require some disassembly.
x2... it happens to everybody the first time...
4" Stubby antenna, Dual arm LEDs Fender LEDs, Back Rest, Luggage Rack, Run, Brake and Strobe for top case, Mirror LEDs,Back Off decal on mud flap, reciptal for Battery Tender and Heated Gear, mirror LEDs that stay on or work with blinkers, GPS, side bag red LEDs, Top cuff with Ram Ball phone holder And USB power, Top cuff with drink holder and passenger cup holder. Also grilles in front of radiators, also spyclops. Garmin 595 GPS, Freedom windshield. Also glove box console And trunk wrap in carbon fiber from wrap my spyder. BRP comfort seat. added garage opener with rocker switch in center console to match other switches. And I have added Elka stage 2 shocks.
SpyderLovers Sponsor
Easy fix
Loosen the 4 bolts. Press hard in the center, it will pop in. Press on the black; the tab is on the painted part, and goes into the black part. Call me if you get stuck! Joe
Joe Meyer
