Results 1 to 2 of 2
    Mar 2010
    Spring Hill FL
    Default Grounding location 13 RTS frunk
    I've installed a 12 volt outlet in my right speaker grill and plan on drawing power from right fuse box in frunk. Where would be a good grounding point close to this location? Thanks for the help.
    American Legion Riders/GA Patriot Guard Rider
    Quote Originally Posted by bruceofthebronx View Post
    If you haven't yet, spend the $28 or so for a service manual PDF. Then look at the wiring diagram and the actual wires to find a good place to tap in for power. And search the forum to see what others have done.
    The fuse box is not a good place to tap into for power. There is no good place to connect to in it, and you stand a chance of damaging it's water tightness. Most everyone gets an auxiliary fuse box with both power and ground and connect it directly to the battery.
