Results 1 to 25 of 32
    Apr 2017
    RAYMOND, IOWA
    Default Cruise Control won't set
    I have a new 2016 RT-S. Cruise shows "ON". Press the cruise button down to "set", and about 1 out of 10 times it will set. Took back to dealer, they say nothing wrong. Brought it back. Set the first time out. Went through a round a bout. Tried to reset, wouldn't set. Turned cruise off and back on, still wouldn't set.
    Sep 2016
    Chillicothe, Oh.
    First place I would check would be the brake light switch. If switch is on cruise won't work. Is your foot making any contact with he brake pedal? It doesn't take much to activate that switch.
    2015 RT , Black
    Jul 2011
    Mitchell, Ontario, Canada
    I would agree with that. If the brake light is on the cruise will not set.
    Apr 2017
    RAYMOND, IOWA
    I would have thought the dealer would have checked that
    May 2013
    Apex, N.C.
    I used to have the same trouble with my 2014 RT. Mine did that for the first 300 miles or so, and then it worked fine.
    Skip ahead to the first 3k mile service. After putting it on the computer, it stopped working again. After 300 miles, it was fine. After that, it never gave any more trouble. Dealer or myself never found the problem.
    Jun 2010
    Las Vegas
    You said you went through a round about, what was your speed when you tried to resume the cruise? If you were going too slow it may not engage.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Bossier LoUiSiAna
    It is for crushing not a round about it also will not engage if your in a bad gear for that speed like trying 60mph in 2nd it will in engage if in 3rd but not 2nd
    As others have mentioned, that brake thing is the first thing to check - like the dealer says, your cruise control might be fine in all respects, but if your foot is touching the pedal &/or the brake light is still on, then the chances are that is the cause of cruise not engaging!! The next thing to check is your engine revs - regardless of what speed you are doing, if the engine revs are below what the ECU believes is necessary to keep the engine safe & not lugging in that gear, or if the clutch hasn't yet 'locked-up' fully on an SE, your cruise just won't set!
    So maybe you just need to keep your revs up a tad higher & try again?!? For the V-twins, the revs need to be above about 3500-3800 rpm; for the 1300 triples, you probably only need about 3000-3200 rpm or so!!
    My 2014 was also plagued by a non-functioning cruise control. We went through all of the potential stuff with the brakes: nothing!
    It turned out that the RH switch housing (and all of the stuff in it...) needed replacing.
    Problem solved!
    Active Member Lobo's Avatar
    May 2016
    Murrels Inlet, South Carolina
    Default Cruise Control Sett
    On my 2012 RT I push UP to set it. When first setting it, I have to hold it for several seconds before it engages.
    May 2016
    Default Setting Cruise Control
    On my 2012 RT, I have to push UP to set. I have to hold it for several seconds when first setting. After that it just takes a quick push UP.
    May 2016
    Sorry for the double post. The first one took a long time to show up.
    Quote Originally Posted by Leatherneck View Post
    Jun 2010
    Las Vegas
    I think your wires were crossed when your Spyder was assembled as on all the other Spyders you push down to set and up to resume. I did hear of another that was set up backwards like yours
    2010 RT- 622
    x 2. If its not the brake switch, I think you are on to something here.
    Active Member johnwinslow's Avatar
    Jul 2011
    Waterboro, Maine
    if you have a sm transmission pulling the clutch in will disengage cruise control as well
    Apr 2012
    Northglenn Colorado
    My friends 2013 cruise did not work sometime shortly after purchase. The dealer fix under warranty. Had to replace something on the Cruise control unit.
    Nov 2015
    Myerstown, Pennsylvania
    I looked at the service manual wiring diagram & it shows that the wires for the cruise switch go to the left handle bar module. I guess from there it talks through the can bus.
    The Critter 2016 RT-S
    Cat Bypass from Lamonster
    BajaRon Sway Bar
    Hella dual horns with relay
    BRP Hitch with trailer module
    Foam Grips
    Adjustable Air Deflectors
    Shorty antenna
    Ultraguard half cover
    Gremlin bell from my son
    Apr 2017
    North Central Florida
    In most automotive applications, "resume" will also function as "set" if you hold it down long enough.
    Very Active Member Fat Baxter's Avatar
    Sep 2014
    Central Alabama
    I've noticed what I think is merely a quirk in the system.
    If I've got the cruise control engaged (say, at 50 mph), then I accelerate up to 65, if I try to re-set to the new, higher speed, it won't take; if I let go of the throttle, the bike drops down to the previous setting. I figure the system can handle only one setting at a time. So, my work-around is to quickly (and gently!) tap the brake pedal to drop out of cruise, then re-engage the switch to set the new speed. Clumsy, but it seems to work for me.
    Maybe something similar is happening to you.
    The cruise won't set if you are accelerating, or pulling hard up a hill. It also won't set if you are going downhill and back off the throttle all the way.
    Columbus, Indiana USA
    Quote Originally Posted by Lobo View Post
    My 2012 RT does exactly the same thing. I have to hold up for 2-3 seconds before it will set the cruise. Once set, I can increase the speed by one MPH with a quick push up, but if I push down to try to decrease my speed by one MPH, it disengages the cruise control.
    Does that make sense considering the possible crossed wire theory?
    Very Active Member Zip's Avatar
    Sep 2016
    LI NY
    Quote Originally Posted by johnwinslow View Post
    Mine won't, the engine screams if I pull the clutch.
    2010 RTSM5
    2010 RTSM5 , stock Stock Silver
    Sep 2016
    LI NY
    Quote Originally Posted by Fat Baxter View Post
    ON mine if it is set at say 50 and I want to increase i simply push up on the switch and hold it it will increase in speed untill i release the switch and then maintain that speed. Works opposite if I hold switch down.
    2010 RTSM5
    Quote Originally Posted by Zip View Post
    ^^ Then there is DEFINITELY something wrong with the switch or wiring if it doesn't disengage with clutch application.... which sorta suggests that you may well have other cruise control issues too?!?
    Apr 2017
    You really should get that fixed.
    It is NOT supposed to work that way.
