Results 1 to 13 of 13
    Very Active Member finless's Avatar
    May 2013
    Stanton, ca
    Default I wish we had this!
    Could you imagine if Spyder Codes had this!
    Come on BRP get us into the 2017's
    http://trynding.com/fixd/
    Bo
    2011 RT-S SM5 - Black
    Nov 2013
    Oro Valley Arizona
    Will this plug and play with the Spyder Bob? This could be your very own "B U D S" system if it will program for the Spyder.
    Jack
    2015 BMW R1200R LC
    2014 RTL SE6 Pearl White
    2012 RT-622 trailer viper red
    2011 Polaris Ranger green
    2016 Can Am Maverick
    May 2013
    Stanton, ca
    Quote Originally Posted by jaherbst View Post
    Jack
    No... It won't work on the Spyder as BRP does not use a standard Protocol. Thus why BUDS exists instead of using a standard ODB-II tool.
    You can probably physically plug it in but that's it.
    Bob
    SoFlo
    Quote Originally Posted by finless View Post
    Bob
    Different plug. No doubt, if someone were ambitious, they might build a reader and it could app to the phone.
    The downside of this is that it may give you the fault code, but often it is very general and the solution may be one of many possibilities.
    Yesterday, neighbors van was running like a turd. Read the obd2 codes with my code reader. Code p0300 random cylinder misfire came up. Sadly, this can be about anything from a bad ignition coil to faulty fuel injection items.
    Neat item, but still, always best to find a reputable shop you can work with and trust, regardless if it car, truck, bicycle, lawn mower or airplane.
    Sep 2009
    La Valle, WI
    I'm and ex auto technition. Fixed is only a fancy code reader for your phone. It will tell you the code it's reading. But cannot tell you what part is bad. Just tell you the area to start your diagnosis. Fuel pump, electrical ect. You still have to follow the trouble tree to find the exact part or wiring failure. Or have the expensive diagnostic tool the techs have.
    2018 F3 Limited , Oxford Blue
    Northern Kalifornia
    I think press eco, set and turn cancel is the same thing.
    May 2013
    Stanton, ca
    Quote Originally Posted by JP58 View Post
    Well that is better than nothing especially if your not a full time Mech and like to try and service stuff yourself!
    Agreed... I was involved with developing diagnostics for Xerox printers and without great expense on sensors and voltage monitoring everywhere, you still have to use the manual and know how to troubleshoot.
    But, to me this is better than NO info at all...
    FYI, if you have ever used or seen BUDS, it helps troubleshoot things faster. YES you can do it without but it sure helps!
    Then somethings you cannot do at all without BUDS. Like zeroing sensors, etc.
    All I am saying is having BUDS on your phone via Bluetooth would be killer!
    Bob
    Jun 2010
    Las Vegas
    Pulling up the code then looking it up on Spyder Codes probably does as much as this.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    SoFlo
    Bob
    BUDS on the phone, and available would be huge. Just not sure BRP would on board with it. Even better would be on board real time diagnositics rather than codes. But that would get expensive in some ways, mimic BUDS, and if it failed that would be bad.
    Keep track of what's going on underneath the plastic, and mind your maintenance schedules.
    ...And remember the "Magic Thumb-Dance" on the buttons; for when things go wonky!
    Active Member SpyderSteveFL's Avatar
    Dec 2015
    South Florida
    I have a cheap ODB II Bluetooth adapter like this https://www.walmart.com/ip/We-offer-...&wl13=&veh=sem that works with Torque Lite app on Android https://play.google.com/store/apps/d...rquefree&hl=en. For < $20 it tells me the basics of what's needed. Like recently had P0303 which is misfire in cylinder 3. Others are right, won't tell you exactly whats wrong but does at least tell you why your check engine light is on.
    NEW/CURRENT (Wife's Bike, I ride Goldwing/Africa Twin)
    2023 RT Limited Petrol Blue Metallic
    Working on the upgrades... so far... Show Chrome Isolator Fuse Block, Tackform Adventure Wireless charger phone mount
    OLD/TRADED
    2015 RT Limited Intense Red Pearl
    Farkles: Ultimate Tallboy seat, FOBO, JT Dash Mount, Lamonster Spyder Cuff, Kradellock, TricLED lighting - fenders, A-Arms, saddlebags, run/brake, Custom Dynamics high brake light, brake modulator, Drink2Go passenger, MUTH turn signal mirrors, Bajaron sway bar, Kuryakyn ISO grips, SpyderTV front grilles & rear trunk organizer, homemade trunk light
    Pending: Elka shocks, Yokohama S Drive rear tire, EVO 595 front tires, Centramatic balancers, Neutrino black box
    May 2013
    Stanton, ca
    Quote Originally Posted by SpyderSteveFL View Post
    Ummm... your saying this setup communicates and understands the Spyder?
    Bob
    Dec 2015
    South Florida
    No Sir, Just comparing it to Fixd but same issues as mentioned above. Agree would be cool to have similar that worked on Spyder.
    Bob
    OLD/TRADED
