Rear Tire Change/Belt alignment/excessive driveline drag
So, I changed my rear tire per Finless Bob's instructions, using the shock bolt removal method. That way wouldn't have to realign the belt. The belt should go back to where it was before. VERY carefully following his and others recommendations to avoid changing belt alignment. But my belt is now hugging the inner flange, so I go to the thread Belt Adjustment video, watch that video, and when I try to do what he's doing, my back tire barely spins unless I give it some gas. Like there's a lot of drag on the wheel (though the belt is right up on the inner flange).
Idea's anyone, dealers locally are swamped and can't get me in for weeks, I'm prepping for first Spyderfest...
Safe Rides,
David and Sharon Goebel
Both Retired USAF Veterans
IBA 70020 |
DRAG
Something is binding ....... I would get rear tire off ground ..... loosen axel nut ..... will rear tire/wheel rotate ( by hand ) freely ???? ( with belt still on ) .... How tight is the belt ( it shouldn't have changed - if you did it Bob's method ) ....... Mike
Are your brake pads hung up on the springs? Double check and make sure they are in the proper place.
2014 RTL-SE6 8,600 miles
2011 RTS-SM5 5,000 miles
2010 RTS-SM5 59,148 miles
2010 RT- 622
How tight is the axle nut? Bearing bind? Just throwing that out there along with others suggest.
Did you take off the rear pulley at all??
Dave,
If you are still having problems I can come over Sunday and help.
Les
2021 Sea To Sky, 2020 RTL
but our benefits don't?
Les, Please, I'm going through the above mentioned steps but belt tension is something I can't check yet. Heading to the local Harley dealer to see if they have a belt tension tester.
I did follow Bob's video and several other tips mentioned explicitly, but had a hard time keeping the right rear tension adjuster cap tight to the swing arm, seems ever time I tightened the nut it would slide back, and I'd have to push on the tire to tighten it back up.......
But all in all, I've now done rear tire and an oil change solo first time... wheeeeeeee
Safe Rides,
IBA 70020 |
TENSION CAP !!!!
Removed Rear Wheel and Tire, thought trikermutha might have had a point, I did remove the drive hub and the disk brake hubs, didn't check bearings much, but on re-disassembly the bearing on the disk brake side doesn't spin like the bearing on the drive hub side....
Safe Rides,
IBA 70020 |
Check and make sure you didn't leave a spacer out of the rear end.
David
OOOOHHHHH this is fun, I think I over-torqued the inner-hub to wheel bolts, when I was reassembling the wheel assembly. Are the two bearings on either end of the spacer tube supposed to spin independantly of each on on proper assembly or does the spacer tube lock those two bearings to spin as a single assembly inside the wheel?
Safe Rides,
IBA 70020 |
There is a spacer that goes on the brake side. Very easy to leave out. It fits between the outer bearing and the bracket that holds the caliper. If you leave it out once you torque the rear axle you can turn the wheel, but is hard to turn.
David
Nope I even used Engine Oil and BRP Grease where the service manual shows when re-assembling and made sure both spacers were in proper locations. But I've now found that when I try to torque the inner hub to the wheel (even at half torque value of 27lbf-ft) the bearings and tube become unmovable, when loose the bearings spin like they should, but as soon as I tighten those 5 inner hub to wheel bolts (using the time tested cross pattern and gradually increasing torque each time around / across the points) the bearings are locked.
Anyone know if that spacer tube is really necessary.... Just thinking if it's not in the bearings spin fine, but it may actually keep the disk side bearing in too.
Safe Rides,
IBA 70020 |
Yea, I marked each piece I removed with index markers to insure I reassembled all components as they came apart, I even keep the bolts and nuts in a weekly pill manager so the pairs stay together and bolt 1 goes back into hole one... as soon as I hand tighten the inner hub bolts, not even torquing them, the bearings stop spinning, they spin fine under no load, I've dis-assembled and re-assembled twice more today.
I never did check those bearings before the initial disassembly, checked the one in the drive hub and it was spinning as it does now, but not the middle and disk side...... All local BRP shops are shut down until Tuesday now, and we're planning on towing the spider down on a trailer. Maybe I'll see if Pitbull or Lamonster can check it when we get there. (busy week though I'm sure.....)
Safe Rides,
IBA 70020 |
Just off the top of my head when reassembling put the axle thru then reassemble . Not sure if this will help but something is not right..
Did the bearings move at all?? where they sit
Are all parts put back correctly>>
http://www.powersportswarehouse.com/...ar/85401/84597
Look at p/n 250. Did you put it in correctly. Also #240. Don't know if you removed it or not. I'm thinking one side is shorter than the other.
David
Dave,
send me me your address and I will ride out tomorrow. How early are you available?
lkingen@gmail.com
Les
trikermutha, Yep, I found that tip in one of the vids or the comments or posts here on SpyderLovers. It helped line the spacer tube (140 in the parts diagram Warlocks post refers to.) up between the bearings (150). And those bearings spin real nice, until I start tightening the bolts (120 / 130 ).
Warlock, yep, I have the same breakdown in the BRP Service manual and lubed each with Motor Oil, lubed the axle etc. Double checked all the torque values. Used a torque wrench with no or the shortest possible extension, I routinely torque bolts / nuts to half torque, 3/4, then full.
Safe Rides,
IBA 70020 |
What in the heck did you do???
2010 RT- 622
DiIk????? Les is coming tomorrow, I've got a trailer lined up and the nearest 8 BRP service shops lined up by their distance and opening time on Monday morning in the hopes someone can let me slide in line before we pack up for Spyderfest. I'll also be calling Pitbull and Lamonster on Monday if none of the local shops can handle my issue before Tuesday at 5 PM when we leave MN for MO.
Safe Rides,
IBA 70020 |
Hi Dave,
I hope all goes well for you! I think if it's binding that hard, there is a spacer missing, misplaced, misaligned, etc. Also, easy to check the rear brake clearance and spin....I doubt if it's the bearings as it ran fine before the tire change....something has moved to a binding place - I know you marked all parts and followed the directions, i.e. torque, etc. However, one part just a little off can be binding the whole system. We have church in the morning, but Sunday afternoon I could come down to help as well if you and Les are still analyzing it! Just let me now and I'll be there if you would like another set of eyes on it!
Happy and safe rydin'
2014 Spyder RT Limited - January 2014, Cognac/Black Seat, #958, born on 1-8-14
Les is planning on being here in Faribault at noonish, c'mon down, I've reassembled it but the 4th time I didn't bother torquing any bolts beyond standard ratchet pull, planning on tomorrows disassembly with Les.
Safe Rides,
IBA 70020 |
Good Luck and let us know what you Guys find out
Hi Dave,
I can be there around noonish as well....see you then! It's a GREAT reason to get out and ride - to help another Spyderlover!!
Jim
Did ya'll find the problem with the bike?
David
