Service Manual
I recently bought on Amazon the service manual CD "Manuals4Mechanics.com". Is it just we or what, I find the CD to confusing incomplete, disoriganized and very hard to use. From what I have seen most of the information is in owners manual that comes with bike. As an example I was trying to find some torque specs today, never did find on CD. Did a search of this forum and found right away. Anyone know of a better service manual for spyders? OK I will get off my soapbox now. BTY my bike is 2012 RTL.
I bought the Green Manual that is available on E-Bay, and it's a definite winner!
This is where I got mine. Service manual, owners manual, parts and accessories catalog in one pdf file.
http://canammanuals.com/can-am-spyder-manual.htm
AKA Jud Smales, Four Year Spyder Ryder!
"Quando Omni Flunkus, Moritati"
The Critter 2016 RT-S
Cat Bypass from Lamonster
BajaRon Sway Bar
Hella dual horns with relay
BRP Hitch with trailer module
Foam Grips
Adjustable Air Deflectors
Driver & Passenger Gel Pads in Seat
Shorty antenna
Ultraguard half cover
Gremlin bell from my son
Break Stripe Kit from Wrap My Spyder
teck spark
I did teck spark ,and had too use an older computer that would run the c.d. .... but it help in the taking apart the cycle and working on stuff , but I did look over a lot of other sites for the exploded views too see what I might be getting into !
I just went to their website. From the description it's the scanned factory manual with added crap you don't need. Green manuals and Midwest manuals will be exactly the same. Don't know about Tech Spark, but I will guess it is the same. Manuals for 2013 and later models are a digital copy of the factory manual and are searchable. So if you are not finding info in the one you got I am guessing one from a different vendor is not going to help.
2018 F3 LIMITED
Exploded parts views are free online from BRP website. Also from many online parts vendors. Also the online version is up to date.
2018 F3 LIMITED
I have found that I have to look at several years of the parts pictures because not everything is on the 2016. Best example is the mirror clips. They are not on 2016 RT blow up but they are on 14 & 15.
BajaRon Sway Bar
Foam Grips
Shorty antenna
