Results 1 to 11 of 11
    Active Member amusher's Avatar
    Apr 2015
    11 Mile/Spinney CO
    Default High/Low Beam Shutters
    Is there a fuse or relay that opens and closes the high / low beam shutters on a 2012 RS? I only have high beams...
    Jul 2011
    Mitchell, Ontario, Canada
    Quote Originally Posted by amusher View Post
    The same fuses and relays control the headlight bulbs too. So if any of them are bad the headlights would not be on at all. The interesting thing is is you say the headlight are stuck on high. Default if there is no power to the shutter solenoids would be in low position. So that means the solenoids are powered and you just can't turn them off. That points to the high/low switch on the left handlebar controls.
    Feb 2013
    APOLLO,PA
    I just had the same thing happen on my 2012 RT, Hi beam only and switch would not work. replaced blown Number 1 fuse 15a fixed mine.
    Nov 2015
    Chardon, OH
    It does seem odd to have high beam only. But anyway, check your fuse and relay box for a relay called HI/LO Head Lamp Relay...or something similar. The switch operates a separate relay for the shutters on the RT. Why would an RS be any different in that department? Relay could be failed or not seated fully.
    Doug
    ”Freedom is not a loophole”
    Default Agree...
    best place to start...
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Apr 2015
    11 Mile/Spinney CO
    Thanks everyone.. I'll go start to search for the trouble...
    Good luck; please let us know what you find!
    Jul 2011
    I did look at the wiring diagram and there is no relay for HI/LO beam. It is not the same as the RT.
    Apr 2015
    11 Mile/Spinney CO
    Ok.. I found the headlight relay in the front fuse box. Pulled it out, tapped it with a screwdriver, put it back in and I have high/low beams again... Go figure...
    Jul 2011
    Well that's a surprise. If it stuck once I would think it could stick again. Replace it with a new one.
    I was under the impression that the wiring on RS was the same late production 2010 until 2012. Obviously that was wrong. Sorry about that.
    Thinks out loud Jeriatric's Avatar
    Apr 2012
    Question Bad or burnt contacts
    Time to acquire a spare?
