Results 1 to 13 of 13
    Apr 2016
    Bloomington, Minnesota
    Default Changing SE6 transmission filter
    Can you swap out the Tranny HCM filter without doing a complete oil change (I.E. can you just drain the transmission side without all of the oil in the engine side tank coming out when I pull the transmission filter?)
    The bike has only 800 miles on it's last oil change.
    Mar 2013
    It's possible, but you would need to have your Spyder on it's left side. I do not recommend that, so I will say no.
    Les
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Sep 2014
    USA
    why do you want to replace the HCM filter after 800 miles?
    Apr 2016
    Bought the bike with 27,500 miles on it. The seller did a fresh oil change, however, the HCM was not serviced. Warranty says I need to change the HCM filter in the 28,000 mile area. So I am doing that now. Do not want to void my warranty, I just extended it....
    Apr 2016
    OK Les, I will do it right....Time is tight. I am moving this week and prepping for Spyderfest....
    Default HCM FILTER
    Papa, I just did mine ..... my RT had been draining for two months so when I did the HCM I barely had any oil come out ...... your's wouldn't go this way .......... so you can do either of two things #1. warm her up drain all oil from both drains into a CLEAN pan and then follow Doc's video, button her back up and put the oil back in ...... or do the drain thing don't bother with the oil filter and then do the HCM , and button it back up your choice .... Mike
    Jul 2014
    United States
    We'll do a better video on the next one. We are at 37k now on the RT, so won't be long.
    Active Member T.P.'s Avatar
    Oct 2016
    APPLE VALLEY, MN
    I see now that I'm going to change that filter at my 25,000 mile oil change.
    T.P.
    Dec 2013
    michigan
    Default Tranny filter
    Quote Originally Posted by PapaHotel View Post
    Run her to the next oil change. It will be fine.
    Nov 2012
    Pueblo Colorado
    Default Like Blue says - run her until you do the next change
    Quote Originally Posted by bluep View Post
    Of all the various services, the HCM filter change while important is not critical at EXACTLY 28,000 miles. You supposedly have a fresh oil change from the previous owner, and if you know what oil was used and what oil you plan on using, just order a new HCM filter from BajaRon for the next time you change oil (end of year or regular 6-9000 mile oil change interval). The filter media in this filter is quite robust, and you are good if the previous oil changes where done as specified JMO
    07 Shadows, Aero, Spirit gone but not forgotten
    03 Harley Sportster, 07 RK moved on
    11 RT- 76,000 mi, 15 RT-S- 44,000 mi, traded for current 15 base RT and 16 F3T
    2015 RT , OEM Black Gloss
    Dec 2013
    michigan
    Quote Originally Posted by AeroPilot View Post
    Right on I have put 40;000 on this filter no problems.
    Default Depends...
    Seems you could just place your oil pan under you work area and catch the oil that drains out when you remove the cover. Personally I would dump it and top off with fresh oil after the filter change is made. Would not wait till next oil change if observing the recommended change period of 9,300 miles. Couple more thousand would not make a difference.
    ​2012 RS sm5
    Aug 2007
    Greeneville, TN
    This one has my vote. This is what I would do if it where my Spyder.
