Results 1 to 10 of 10
    Mar 2013
    Clarksville TN
    Default Space bar inoperative when I "reply with quote"
    Title really says it all. Anywhere else on the internet and/or this forum the space bar operates. When I type a "reply with quote" on this forum, there are no spaces between words. If I go back to my sentence with the cursor, I can insert spaces. What's up?
    2015 F3 (wife's)
    2014 Indian Vintage
    2019 AMG C43 cabrio
    1966 LS1 Corvette restomod
    1956 Corvette survivor (wife's)
    1941 Chevy hotrod truck
    2023 Corvette Z06
    Active Member Spider-man's Avatar
    Mar 2017
    San Antonio
    Quote Originally Posted by petegtsv10 View Post
    I've had the same problem, even had it now replying to this. If I hit the return key and then back up my space bar works.
    Very Active Member Y Rider's Avatar
    Oct 2010
    Springfield, MO
    Seems to be working correctly for me. However, I am using Microsoft Edge 38.14393.0.0.
    MODS: Elka Shocks, ESI RT HMT Brake Light, ESI RT Brightsides, ESI Fender TIPS, ESI RIPS, ESI RT Day Runners, Grip Puppies
    AmerSeal Sealant, KewlMetal Kewlock, Scorpio I900 Security System, Stebel Nautilus air horn, KewlMetal Highway Brackets & ISO Wings
    Corbin seat, trunkrest & driver backrest, Capt.Jim's Belt Tensioner, SpyderPops LaBlock, Cat Shields, Bumpskid & Belt Guard
    Seal PUP Floorboards, BRP chrome, Ron's Anti-Sway Bar, Lamonster LED Head/Fog Lights & BRP Air Scoops
    2011 RTL , White
    Feb 2009
    Ceresco, Michigan
    Yup.. it does that sometimes.. just hit 'enter' a few times then it goes away.. you can then go back up to the top and type like normal.
    Strange interwebs...
    I've noticed that TapaTalk no longer works either.
    It's a little more work; but here's how I've coped with this phenomenon:
    I'll simply highlight the copy from another post, then copy, and paste it into mine.
    (Putting quotation marks around it; once I've got it in place...)
    Jul 2011
    Mitchell, Ontario, Canada
    Period, Return, Return. Then the spacebar will work just fine.
    I have the same problem. Also on PM replies. I'd say same system.
    I hit the 'Enter' key. It drops down a line and then the space bar works. Or, you can put a comma (') between each word!
    Plenty of workarounds. But a very unique problem. I've not encountered it anywhere else.
    Nov 2015
    Myerstown, Pennsylvania
    I have had problems with it too when replying with a quote. I found if I start right at the end of the quote everything works fine. When I'm done I put the cursor at the beginning of my response & hit the enter key to space my stuff away.
    The Critter 2016 RT-S
    Cat Bypass from Lamonster
    BajaRon Sway Bar
    Hella dual horns with relay
    BRP Hitch with trailer module
    Foam Grips
    Adjustable Air Deflectors
    Shorty antenna
    Ultraguard half cover
    Gremlin bell from my son
    Default Ongoing....
    Sporatic as to who..must be some operating systems. I have it only if I want to reply to a post. Then the steps above work...
    Mar 2013
    Clarksville TN
    Of the "solutions" offered, yours is the only one that works for me. Thanks.
    2015 F3 (wife's)
    2014 Indian Vintage
    2019 AMG C43 cabrio
    2023 Corvette Z06
