Question about trailer hitch
I understand that the show chrome hitch will work for the RT, ST, RS, and GS. I know that the F3 looks totally different, but the swing arm on the F3T looks more similar to the previously mentioned bikes. So, will a hitch from a RT fit a F3T?
Yes it will fit. The swing arm is the same.
The BRP hitch that I took off my 2013 RT LTD fits onto my F3T. As stated above the swing arm is the same. I just need to get that wiring harness set up for my RT622 trailer.
The wiring harness harness from the RT will fit the F3 too. Did you take it off?
I could be wrong on this but i believe that the wiring harness for the RT and the F3 are different, the Hitch is the same.
Cruzr Joe
Thanks guys. I don't have a wiring harness on the RT, as I just use the hitch to attach my Doc Humphries rack. Thanks again.
I was relying on info from Lamonster Garage which says that they are different wiring harnesses and are not interchangeable.
Cruzr Joe
Cruzr Joe
BRP harness will work. Show Chrome harness for RT will not. Other after market may not as well.
