Results 1 to 20 of 20
    Aug 2015
    Northern California-Sierra Mountains
    Default Does ECO mode actually change anything?
    Does eco mode actually change the "power band", acceleration, or fuel delivery etc. OR does it just give you a green arrow designating when to shift? Have read conflicting info. On the forum.
    Active Member monkeyboymorton's Avatar
    Sep 2015
    UK
    Quote Originally Posted by Steamer View Post
    It changes the amount of throttle range you have:
    • In normal you have 0-100% throttle opening across the twist (as you would expect)
    • In ECO you have 0-60% throttle opening across the twist.
    So it restricts power by restricting max throttle opening. It doesn't alter anything else and is no more 'economical' than you using less throttle in normal mode. Hence most people consider it pointless.
    | 2015 F3-S | Heated Grips | USB Ports | RAM X-Grip | RT Sway Bar | '2 Up' Rear Shock | SHAD Bag Kit | Oxford Aqua 50 Dry Bag | BRP Rider Backrest |
    Default Well....
    It does change your greyhound into a bloodhound..... what I have not seen is if there is a significant savings by using it....
    ​2012 RS sm5
    Aug 2015
    No Mo ECO for me!
    I faithfully used ECO mode for one tank of gas. I saved about one mpg. Found the green arrow telling when to shift to be a distraction. I no longer use it.
    Could we have the electronic frunk release back?
    It saved me even less than that: only a couple of tenths...
    MBM is correct about the throttle:
    Registered Users Mr. Pickels's Avatar
    Feb 2017
    North West Arkansas
    Default Nice chart
    Non-ECO mode way more fun, ....she is a pig on gas either way who cares have fun!
    We now have an antidote available for ECO mode: it's called Sport Mode, and you can get it in some of the F3 models!
    Feb 2017
    North West Arkansas
    Default Hmmm
    I'll have to see if my new F3-t has that....
    Sadly: the Ts don't...
    Dec 2013
    I thought that along with the Daytona's, both the T's & the Ltd's DID have Sport mode?!?
    They left it off of the Touring and Limited models...
    Nov 2012
    Pueblo Colorado
    Default No S mode on the wifes F3 T
    No S mode on the wifes 2016 F3 T. If the 'burn rubber mode was what you were lookin for, the S mode was your choice. Sometimes the lower trim levels suit your needs better and then add your needed farkles to customize. Wife runs through enough tires without encouraging extra hooliganism.... YMMV
    2015 RT , OEM Black Gloss
    Dec 2016
    Somewhere USA
    I did a full tank of gas with and without while keeping track of my MPG (gallons divided by trip meter). The ECO dumbs down the throttle and nothing more. I kept my bike performing the same in eco mode and by doing so my MPG was the same. If you want a less responsive throttle use ECO mode but expect nothing else in return.
    Side note. My car has the same eco button and I tested it like I did the Spyder. Another useless virtue signaling piece of garbage by those wishing to "Go Green".
    If you truly care about the environment....WALK!.....otherwise don't be a hypocrite.
    Very Active Member GaryTheBadger's Avatar
    Jan 2009
    Northwest Arkansas
    I get about 1 MPG more in Eco mode on a stock 2015 F3S. It also keeps me out of trouble, so I leave it on 99% of the time. Personal preference.
    Enjoying now: 2015 Spyder F3 SE6, 1970 Indian MM-5A, 1972 Suzuki RV90J Rover, 2017 Indian Chieftain (wife's)
    Wish-I-had-kept-them: 2008 Spyder GS SE-5, 1967 Shelby GT500 w/Paxton supercharger, 1972 DeTomaso Pantera, 1991, 1992 & 2001 Acura NSX's, 2012 V-Star 950 Tourer, various 2-, 3- and 4-wheelers
    2015 F3 SE6 , White - The fastest color!
    Very Active Member vondalyn's Avatar
    Jun 2012
    Longmont, CO
    Default Eco Mode? EW!
    Nope, don't use it. I'm averaging 40mpg without ever using Eco Mode, and I'm kind of a hooligan, so it's possible to have fun and still get good mpgs.
    We now have His and Hers Spyders!
    Current Spyder: White 2015 F3-S SE6
    His Spyder: White 2015 F3 SE6
    Previous Spyder: 2012 RT Limited SE5 -- 30,300 miles
    Previous rides: Kawasaki & Honda
    2015 F3 , Pearl White
    Sep 2015
    UK
    I've only found it useful for really cold / wet / slippy weather to damp down throttle response and avoid wheelspin.
    Sep 2015
    UK
    Cheers Bob knew I'd seen that graph somewhere on here!!
    Feb 2017
    North West Arkansas
    Default I agree
    Quote Originally Posted by vondalyn View Post
    ...after spending my life savings to buy this thing lol... I really don't care about mpg
    I might have had the .jpg file... but you had the correct numbers to go along with it.
