Brake Fluid Capacity
Changing brake fluid on a 2015 RT-Ltd
Getting some conflicting info on how much fluid the RT holds.
2 different pages from my service manual, 1 says 1.75L - 1.85QT the other says 530ml - 17.9oz
Anyone know which is correct?
can't help....
cause I don't know the amount and have always filled to the full level or leaving enough space for the cap, If I fall short the nanny tells me right away...
Brake fluid
I think they both are. One is the capacity and the other is the amount of fluid required to fully purge and bleed the system. You will lose some new clean fluid in the process so they show the greater amount to do it. That's different from its technical capacity.
Lucky
2015 RTS SE6
2008 Harley Ultra
1999 BMW R1200C
1986 Harley Electraglide
I flushed mine following the instructions in the manual and it took about 1/2 Qt.
2015 RTS Special Series
Russell Day Long seat
F4 Customs windshield
Sena 20s
Finished the brake fluid flush and used roughly 800ml - 27oz
