I have a gremlin
Got a small problem I hope someone out there can help with.
I have a 2016 RT Limited the problem is when traveling down the road with cruise control
on and I go to use turn signal to change lanes cruise control turn off. Also when the MP3 player
is on and I hit the horn the music stops for a few seconds.
Any ideas what's going on.
Thanks,
Butch
Just curious about the turn signal / Cruise control connection, do you have any add on lighting on the turn signals?
Safe Rides,
David and Sharon Goebel
Both Retired USAF Veterans
IBA 70020 |
no I don't
You may be inaverntly bumping the shift lever mor than it likes?? Shifting gears will cut out CC.
Hopefully thats all it is.
2013 STL SE5 BLACK CURRANT
SpyderPop's: LED bumpskid
minispyder dash toy
Lid lox
KradelLock
Pakitrack
FLO (Frunk Lid Organizer)
BRP fog lights, trailer hitch
SENA 20S EVO
CC should always kick out when you use the shifter
This might just be part of how the system works...
If you're signaling for a lane change: you should ideally be in full control of the bike...
(You don't want to start a lane change, and put yourself right into the line of fire! )
And why would the music from the MP3 stop when I hit the horn
I have a 2017 RT, and it doesn't drop the CC when you put on the turn signal
2017 RT-S
Bump Skid - Spyderpops
Wrap - Wrapmyspyder
swaybar - Bajaron
Sena 20D & SM10
3 PC Mesh Zippered Lid Net Set - TricLED
A arm LED's - Safety LED's - TricLED
Mirror Sequential turn signals
Glo-riders
LED rear turn signals and reverse lights
Front Grills
Third Brake light
Larson Scanner
Light Up - Sue Hopper
Thinks out loud
When in doubt
I would have the dealer look at it. It sounds to me like there's a potential wiring harness issue.
Ozzie Ozzie Ozzie
Just looked at the service manual & the load shedding relay is on the same circuit as the radio along with the rear heat. You should see if turning on the rear heat effects the radio the same as the horn. They are all fed off a 40 amp fuse, RFB Accessories fuse (J2).
I just found the cc switch on the print. It is wired over to the left switch module & probably talks thru the can bus. Hope this helps.
AKA Jud Smales, Four Year Spyder Ryder!
"Quando Omni Flunkus, Moritati"
The Critter 2016 RT-S
Cat Bypass from Lamonster
BajaRon Sway Bar
Hella dual horns with relay
BRP Hitch with trailer module
Foam Grips
Adjustable Air Deflectors
Driver & Passenger Gel Pads in Seat
Shorty antenna
Ultraguard half cover
Gremlin bell from my son
Break Stripe Kit from Wrap My Spyder
Ozzie Ozzie Ozzie
Or touching the brake pedal!! Cruise disengages when you brake. And as some have found, the return spring on the brake pedal can get a little weak over time, so it can sag just enough to activate the micro switch for the brake lights, putting them on & thereby dropping the cruise - or even preventing cruise from going on in the first place, simply because the brake lights are already on!!
BajaRon Sway Bar
Foam Grips
Shorty antenna
Gives me a place to look..
Thanks
Should be under warranty, correct ?
The cruise control switch connects to the left side multi switch, which is a CAN bus processor. That processor controls headlight hi/lo beam, turn signals, and all the audio controls. The horn button is in that switch but is a normal electrical push button, but its ground side is common with the ground of the processor.
I think you have a bad CAN bus processor. The turn signal is mucking up the signals from the processor causing the processor to send out a CC cancel command. The horn button is causing a spurious signal through the ground connection that is causing the processor to send out a volume mute command.
Another possibility with regard to muting. Do you have a headset, either Bluetooth or wired? If so, maybe the horn sound is being picked up by the mic putting the headset into intercom mode thus shutting off the audio volume.
2014 Copper RTS
Your title mentioned Gremlins, is your bell malfunctioning? Do you have one? Two? Three of them on the BKE.
Joe
U.S. Army Viet Nam Era Vet
Utopia Deluxe driver backrest
LED fender lighting
Fast Flash LED brake light
Spyder Pops LED/skid plate
I MAY have a clue. I just encountered the same thing last night so I did some testing. Here's the setup. I have Bluetooth adapter in the trunk with the iPod connector plugged into it. I have two 12 volt to USB power adapters in the space under the headlights. The USB power adapter has an on/off switch so I can turn it off when not needed. One of the adapters goes to the phone to keep it charged while I'm listening to Pandora. The phone is connected to the BT adapter in the trunk. I also have the CB communications system and am listening via wired headset.
When the switch to the USB power adapters is off, and the cord is plugged into the phone, and the phone is playing Pandora via the BT adapter (AUX on the screen) every time I press the horn button the audio mutes while the horn is blowing and for a couple of seconds after. I checked and the audio will mute for every audio source. If the USB power adapter switch is on, no muting. This is what I encountered last night.
I can't see the connection between the switched off USB charge cable being plugged into the phone and the horn blowing. The only electrical tie in between the two, when the USB adapter switch is off, is the ground for my air horn compressor and for the USB power adapter both go the auxiliary fuse panel I have.
I just did some more testing before I posted this. The horn mutes all audio when the USB power adapter is switched off. The charger cable does not have to be plugged into the phone, and the BT receiver nor the iPod have to plugged into the aux audio port in the trunk, i.e., I unplugged the iPod adapter cable. The bike has to be running. The muting does not occur when the cluster is powered up by holding in the mute/eco button when the key is turned off. The USB switch has to be off when the bike is started. If the switch is on when the bike is started and then turned off, the muting does not occur.
The speakers also mute. I checked with external speakers on and off, and the headset in off or mix mode.
Weird is all I can say at this time. There must be some sort of glitch being generated in the CAN protocol somehow. It does provide me the benefit that if I'm using the phone to listen to Pandora, and blow the horn, and the audio mutes, I know the power to keep the phone charged is switched off, and the phone will die in about a 1/2 hour or so.
2014 Copper RTS
