Results 1 to 11 of 11
Thread: lifeless spyder
    Active Member cenzo989's Avatar
    Apr 2016
    Staten Island, NY
    Exclamation lifeless spyder
    hey guys, got a little situation here]...
    i sat on my bike this morning.. i put the key in and turn and then the bike does the normal pre-start
    press the brake pedal and i see the rear light brighten
    presss the start button and i hear a POP but not very loiud
    then the bike shuts down
    no brake light no nothing when i turn key
    nothing ...
    lifeless....
    im freakin out..... any ideas??
    Invalid Emails
    Feb 2013
    Castle Rock, Co.
    Quote Originally Posted by cenzo989 View Post
    nothing ...
    lifeless....
    Not a Mechanic but did you check all the fuses if you do not get the dash light to come on could be electrical best guess good luck..jtpollock
    Invalid Emails
    Oct 2015
    morgantown west virginia
    clean and tighten your battery terminals. might be as simple as that.
    Jun 2015
    Hampton Roads, VA
    Default Sounds like battery...
    With NOTHING working - brake lights, dash, etc. means a complete power failure. All those things are on different fuses, which means power to the fuse box is gone. Measure the voltage on the battery, check terminals. I don't recall if there is some type of inline fusible link on the positive cable of the battery, so trace it from battery to the fuse box. A popping sound might be the positive cable shorting to ground from rubbing on something, the battery having an internal short (unlikely), a terminal falling off the battery (screw got loose and fell out), etc.
    Apr 2016
    Staten Island, NY
    Quote Originally Posted by stevencovert View Post
    With NOTHING working - brake lights, dash, etc. means a complete power failure. All those things are on different fuses, which means power to the fuse box is gone. Measure the voltage on the battery, check terminals. I don't recall if there is some type of inline fusible link on the positive cable of the battery, so trace it from battery to the fuse box. A popping sound might be the positive cable shorting to groundow that i think of it from rubbing on something, the battery having an internal short (unlikely), a terminal falling off the battery (screw got loose and fell out), etc.
    now that i think of it, i did loosen the battery terminals to take out an asseories attached to it.
    and i dont think i screwed the terminals all the way back in...
    can it be because of that?
    could it be the screw got loose, and everything turned off?
    i hope to god your right
    i will look at it tomorrow morning and let you now
    Feb 2012
    Spring City,Utah
    The POP you heard was probably the electricity arching across an air gap on a loose battery terminal which then caused the cable to lose connection to the battery. Hopefully it didn't take any(or too many) fuses with it. Tighten BOTH cables at the battery. check you fuses (yes all of them including the main fuse). Then and only then turn on your key and see what you have. Good luck.
    And don't worry you aren't the first or the last to forget to tighten a cable.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Default All of the above
    Re-check all the electrical connections. Any loose ones will result in these kind of problems. Hopefull it was only at the battery that you worked....
    ​2012 RS sm5
    Was it a loose battery connection?
    Sep 2016
    Chillicothe, Oh.
    Anytime you repair or modify your spyder/motorcycle/car/truck/mower/chainsaw/toilet and then you have an issue with them later you go back to what you did last. Most of the time you will find the problem. Works for me anyway.
    2015 RT , Black
    Apr 2016
    Staten Island, NY
    Red face update
    hi guys,
    i am so sorry for delay in response
    the weather here in NY has been so ****ty with cold heavy rain and wind....i didn't get a chance to get to my garage to check on the spyder
    but this morning was beautiful, so i went out..
    long story short....you guys are lifesavers..
    it was a loose terminal screw i didn't tighten enough
    whewwww..i worked on putting the battery on a battery tender to charge it the day before the incident..
    i guess when i put it back, i didn't tighten the screws to the battery..
    i love you guys... and thanks for the quick response also..
    Very Active Member HayRog's Avatar
    May 2013
    Sacrament0, CA
    Kinda nice when the fix is easy.
