AUDIO for F3s
Looking for suggestions for radio and music for my 2015 F3s. Shark or boss or what ? Thanks for the help, just would like to do it right the first time.
MOgang Member
I'm happy with this one: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 It will blue tooth to your phone if that's the way you are going to play your music. There is lots of info on this site of other models as well..
X Man
Well
The best sound system you can get is a Bluetooth head set connected to your phone or MP3 player. That way you can keep the music, that you enjoy more than anybody else, in your ears where it is most appreciated.
Shark install on my F3 (Lamonster's install also)
F3S owner here.
I thought I had this all nailed when I took out my Bose noise cancellation earbuds the other day expecting to get some decent quality music while dampening the wind noise levels. To my disappointment, the wind gusts caused the noise cancellation to go crazy by cutting in and out making it feel a though there was a shift in pressure in my ear - not good! After 5 minutes I couldn't bare it anymore and pulled over and threw them in the jacket pocket. I also noticed that with the helmet fitting snug that the buds shifted around a bit as well.
Next step will be to try a regular pair of headphones.
I got the 800 watt Boss that is BT. I also have Sena 10's, so I can go either way. Cruising around I will the Boss, and out on the interstate the Sena is the only way to go. Since I stream from my phone I also get turn by turn audio when I run maps on the phone. $99 for the Boss and even though someone said it had some bad reviews it has worked perfectly for me. I'd buy it again in a heartbeat.
CUSTOM IS THE WAY TO GO.
20160313_115250.jpg MAKE YOUR CUSTOM SYSTEM.
Originally Posted by jtpollock
Shark Audio not too costly sounds good easy to install jtpollock
I went with the shark and I also have it connected to my zumo 590. I love all the options I have with this setup
Found another option for music...
My wife recently purchased a new Bluetooth speaker for using around the house, on the deck, etc. and that thing really rocks out. so I was thinking it would be a very good option for tunes on the bike-easy set up, can connect several of them together to several devices. Totally waterproof as well.
Here is a link:
https://www.amazon.com/JBL-JBLCHARGE...eaker+charge+3
Fab up a bracket or two or some Velcro to hold it in place & would be good to go....
Just an idea...
2015 F3-S in Magnesium with Can Am red frame
Blue Ridge Windscreen
Heated Grips
Name of my F3-S - Sandra
Xmas present to me and from myself on 6/11/2015 - 02/09/2018
2019 F3-S Special Series in Liquid Titanium with Orange frame
Heated Grips
Signature Light with switch to turn it off and on.
Name of my F3-S - Pamela
