WTB Small trailer for Spyder.
Small pull behind trailer for Spyder. I do not have a hitch yet. May even entertain looking at the one wheeled unigo.
Harbor Frieght
$280ish on sale. Takes about 2 hours to put together. Pulls nice, better with some decent weight, will bounce around empty when you hit a small pothole! Your choice on hitch, I went with showchrome hitch & wiring as I won't be pulling trailer but 2-3 times a year. I couldn't spend $4K on a BRP trailer (wife would shoot me).
Get the Harbor Freight Trailer
I bought the HF trailer with no regrets. Pulled to Spyderfest last year and just hummed along at 70 mph.
2015 RT Ltd SE6
Intense Red
BaJa Ron Torsion Bar
BaJa Ron Shock Adjusters
Premium Driver Seat Back Rest
Diamond R Spyder Armrests and cup holders
Wheel Aligment Squared Away
Trailer Hitch Value Accessories
Harbor Freight trailer black
Stebel Nautilus Compact Mini Black
139 decibel air horn
Garmin GPS
Be sure you remember to repack the HF trailer wheel bearings with decent bearing grease. They basically put cooking oil in at the factory and not very much of that.
Happy TRAils/NSD
Paul
2012 RT L
AMA 25 years Life Member
TRA
PGR
Rhino Riders Plate #83
Venturers #78
TOI
The HF trailer, but I removed some of the leaf springs and had the tires balanced. This pulled well empty. I used plywood for a deck, but many have used diamond plate aluminum.
Sent from my NX16A11264 using Tapatalk
Reason: OOPS.
BRP Freedom Trailer, Hooked it up and drove away happily. no extra work or parts needed.
Cruzr Joe
Trailer
I bought the Harbor Freight Tag A Long Trailer and bought an after market hitch off eBay, I also used an after market tail light converter and connected it to OEM connectors from Tricled so it was all plug and play. The trailer pulled fine with the 8" tires, you may want to upgrade them to the 12". But you will need to upgrade the lights to LED's in order for them to flash correctly with the Spyder at least on the RT.
