Results 1 to 13 of 13
    Active Member markyodo's Avatar
    Columbus, OH USA
    Default What is this plug for?
    I found this when I was tracing wires.
    2014 RT Base model. It's by the front right side next to the plugs for the fog lights.
    Thanks...
    Sent from my SAMSUNG-SM-G935A using Tapatalk
    Our Scenic Life - Spyder Videos
    https://www.youtube.com/channel/OurScenicLife
    Ask me about my Spyder.
    2014 Black Can-Am Spyder RT
    Very Active Member M109Dreamer's Avatar
    Mar 2011
    Jackson, MS
    I have an 11 RTS. And that looks like the plug for the frunk electric release.
    Sent from my SAMSUNG-SM-G920A using Tapatalk
    2007 M109R LE - To many MODS to list. Its cheaper that way!!!
    Default Here's the thing....
    Don't know but if everything is working don't worry too much. They make one harness for that model and have connections that may not be used on yours. You can add them and just plug it in what ever it goes to....
    ​2012 RS sm5
    Sep 2012
    Stetson, Maine
    Plug for frunk switch.
    Invalid Emails
    Nov 2014
    USA, FL, Venice
    Quote Originally Posted by safecracker View Post
    This is the correct answer. To the original poster, when looking at the Spyder from the front, you should see a micro switch on the left side of the frunk latch. That's the wire which plugs into the back of that switch.
    Jun 2010
    Las Vegas
    Mmm
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Jun 2010
    Las Vegas
    I think that's the connector for B.U.D.S ................... Mike
    No the BUDS connection is larger
    2010 RT- 622
    Columbus, OH USA
    Thanks everyone. I will go with frunk switch. Must be a leftover from previous years.
    Idaho
    Quote Originally Posted by markyodo View Post
    It's the connector for a dual purpose microswitch. With the frunk lid closed it closed the ground side of the electric frunk release so the panel switch would open the frunk. It was standard on the RTS and RTL through 2013. 2014 on it's an option for all models. With the frunk lid open it closes the circuit for the frunk light which is standard on the RTS and RTL. It's an option for the base RT.
    2014 Copper RTS
    Quote Originally Posted by SpyderAnn01 View Post
    Mmm
    Ann,
    Are you thinking about buying a switch, and seeing what happens next??
    Nov 2012
    Pueblo Colorado
    Default Dcoes anyone have the part # for the Switch and Dash Button?
    I've got the 15 base RT and its been a couple years since we traded the 11RT away, but still miss the utility of having the "pop a Frunk" option. Now if I could get a remote FOB operated version!!
    Lamont??
    2015 RT , OEM Black Gloss
    Idaho
    Quote Originally Posted by AeroPilot View Post
    Lamont??
    Electric actuator was one of the first farkles I put on the 2013 base RT I had. Short time later learned all you have to do is press the key down and turn it even when the engine is running to open the frunk. Decided then and there the actuator had been a waste of money! Can't say as I miss it at all on my 14 RTS.
    2014 Copper RTS
    I can't wait to see what you come up with!
