Results 1 to 5 of 5
    Active Member Tx web rider's Avatar
    Jun 2011
    Aransas Pass Texas
    Default 2009 GS sputtering
    2009 GS RS5 80K+ miles
    did the oil change with BRP kit 2 weeks ago after sitting for like 6 months
    wife was saying it didn't want to shift after a mile or so she said it wouldn't go out of 1st
    so i went and drove it and after a while it did it to me
    no indication on the dash display stuck in 2nd gear would not go over 2600 rpm without stuttering
    shut it off and re started it still had issue so limped it home shut down i noticed the alarm for the brake was not making noise
    after a few min i started it and it shifted down to 1
    tried up and down worked but did not drive it and the brake alarm worked when shut down
    any ideas
    i don't have a dealer any where near to get it tested
    The fact that it wasn't shifting propterly, and it's an SE5 bike: did you check the oil level?
    The sputtering sounds as if it's in Limp Mode: did you see any warning lights on the dash?
    (Did you try pulling up any error codes?)
    Default SPUTTERING
    with Bob make sure the oil is correct level ...... and have you ever had the vacuum tubes ( for throttle body )re-placed ????? ...... plus how old is that gas ????? ......... Mike
    Jun 2011
    Aransas Pass Texas
    Default sputtering
    there was no indications on the display no lights
    gas was half tank added half to top off
    not sure how to pull codes on a GS
    MOgang Member Yazz's Avatar
    Nov 2009
    Cypress, Texas
    Quote Originally Posted by Tx web rider View Post
    The same as for a RS.
    Joy
    Very Happy Ryder...
    '09 Phantom and a '15 F3-S
    If you don't slow down, they can't catch you..
    ​If you don't give up, they can't win.
    What a long strange journey its been.
