Surging
My 2011 RTS-SE5 now has about 18,000 miles on it. Lately it has developed a slight surge when cruising steady at highway speeds. Outside temperature and humidity have no effect. I use high octane gas. Vacuum hoses are new, plugs and wires are new. Air filter is new. Speed and RPM do not register a change. The surge is slight, but very annoying.
I searched for answers, but did not find any. There were all kinds of suggestions. It seems a lot of folks have had this problem.
Has anyone actually found a fix?
2011 RTS (Sold to a very nice lady)
1998 Honda Valkyrie
2006 Mustang GT. Varooooom!
US Navy Veteran
SC Law Enforcement Boat Captain
CNC Machine Service Technician
President: Rolling Thunder SC1
Member: Disabled American Veterans, Rock Hill, SC
Member: American Legion
Experience is recognizing the same mistake every time you make it!
Bump
1998 Honda Valkyrie
US Navy Veteran
come to think of it mine does that. I figured it had something to do with the clutch pack. i'd forgot all about it. haven't been on the highway with it since last fall.
When I had ny 2011, I bought it from an older guy and he put 250 miles on it. This was the first spyder I ever rode. It had a huge surge when down shifting and I rode it for 3000 miles like that. It wasn't until I took it in for service I learned that bit was not supposed to do that. Turns out the clutch pac was toast and it was never releasing completely. They replaced the clutch pac with a new one under warranty and never had that problem again. your post, however, sounds like it is doing it under speed. that is different that what mine was doing. just thinking out loud.
2015 an Am Spyder RT Limited
2013 Yamaha WR250R - Sold
2011 Can Am Spyder RT-S SE5 Limited - Sold
2011 Aspen Sentry Trailer
2003 BMW K1200LT - Sold
2007 Unigo Trailer - Sold
2001 BMW K1200LT - Sold
2001 Honda 750 NightHawk - sold
2015 RT Ltd , Canamspyderaccessories Brake pedal ext. Red
Interesting. ...
does it feel like engine surge or traction. Some oils will cause the clutches to do this or there is a clutch problem. On the engine side could be a gasoline of filter problem. Moisture in the fuel system or a dirty filter. If the filter has not been changed it would be a good time to change it anyway.
2012 RS sm5
I'm using Amsoil from Ron. The fuel filter is the only one I have not changed. I'll give it a try.
1998 Honda Valkyrie
US Navy Veteran
I'd have the dealer check to make sure that your throttle position sensor isn't getting a bit wonky...
Now that you mentioned it
I'm getting ready to investigate clutch woes on my machine as well. I had posted about creeping at stops and the centrifugal clutch was mentioned as a possible culprit. Surging at speed as well.hmm, I guess I'll do the whole thing,clutch pack and all. Parts are kinda pricey but considering 62k miles meh
Let us know what you determine. If you please.
2011 RTS 2006 Yamaha Morphous
2017 F150 2015 MINI Cooper S IBA 56167
SpyderLovers Sponsor
Diagnostics
Change fuel filter.
run a bottle of sea foam thru.
once fuel system is eliminated from the problem, look at clutch.
Joe Meyer
The problem I am having is very slight and very consistent. I'm going to start looking at a fuel delivery issue. If it were the clutch I would expect a more abrupt surge and also see a change in RPM.
This is just an annoying problem that is becoming a crusade.
1998 Honda Valkyrie
US Navy Veteran
I owned a 2010 Rt SE5 and my clutch pack came apart. The C clip fell off and the washers from the clutch pack fell off getting chewed up and sucked into both oil filters.
I did not notice surging but rough shifting compared to when the clutch pack was fixed. Repairing the clutch pack was under extended warranty as it cost $4500.00 CDN to fix.
What you describe is definitely a bad clutch. This is the main reason I moved up to a 15. the idea of now having a hydraulic clutch makes riding a marvelous worry free ride now. If at all possible, when at the dealer - get yourself a 14 on up bike! You will NEVER regret the move!
Try this first....take off the right side panel and pinch off the line to the purge valve, then go for a ride. See if your slight surge goes away.
Sent from my Nexus 6 using Tapatalk
That's quick and dirty. I'll try that first. Can't do it until Saturday, but I will post a follow-up on your suggestion and that of the others. Thank you, everyone.
1998 Honda Valkyrie
US Navy Veteran
Update
When the cause of a problem just doesn't jump out at you, try the simple stuff first. My suspicion was a fuel delivery problem, so I decided to change fuel. I ran the tank of 93 octane gas to empty and filled it 87 octane. The surging went away almost immediately.
I had used 93 octane almost all the time and had the surging, so it wasn't that I just got a bad tank full when the surging began. I'm going to run some Techron for a tank and try the 93 octane again. If it starts to surge again, I'll go back to running the 87 octane.
1998 Honda Valkyrie
US Navy Veteran
surging
hi grandpot
my 2013 RT did this also
its almost imperceptible but you know its there..i tried to kid myself that it was wind bufferting
it seemed worse after the heat recall,so much so that i got rid of it
i used super fuel always which is just below avgas here..i tried a fuel controller but just wasted my money
i now have a 2014 RT and the motor is a gem
when i ease out the clutch it dosent rev up all by itself(to 1800 rpm)..that feature alone drove me nuts,i had to wait for the revs to die down before shifting again when shunting
hope you get it sorted
russ
My RT is doing the same thing. Are you still running 87 or did you go back to the 93 octane after the Techron?
After awhile I still had surging with the 87 octane, so that was not a cure. I went back to 93 octane.
I then did a canisterectomy. http://www.spyderlovers.com/forums/s...canisterectomy
So far the surging has stopped completely. I was going to wait awhile before I posted this result for fear of being premature, but since you asked, it appears to be the correct fix for the problem.
Reason: fixed link
1998 Honda Valkyrie
US Navy Veteran
Do yourself a favor and use a product that was designed to be a fuel system cleaner; SeaFoam isn't.
Berrymans B12, Gumout and Techron are much better cleaners.
Then......a wild guess:
Brake rotors are never absolutely true; a slightly sticking caliper can cause a feeling like surging. Easy to check.
So could a bad spot in the drive belt or a tire going bad.
(Edit: I see that the fix took an entirely different turn. It is important to note that the canister only becomes a problem IF it ends up with liquid gas in it......and that most often happens by over-filling the tank. The thread provided also had some suggestions for "fixing" the canister.)
Thanks Grandpot, I will ponder this for a while.. I bought the bike used so I suppose the EVAP canister could be completed saturated.
