Results 1 to 6 of 6
Thread: Swaybar
    Mar 2017
    Minnesota
    Default Swaybar
    New bee to Spyder so be patient. Just purchased a 2017 F3 Limitted and will ride two up a lot with lots of road trips pulling a trailer. I've noticed going down the road at times the bike just kinda drifts to the side of the road and wondering if I change the swaybar if that will help? Also how big of job is it on the F3. Thanks for advise!
    Very Active Member bcer960's Avatar
    Jul 2016
    Kamloops B.C.
    Quote Originally Posted by I-Day View Post
    I can't help with the F3 part, but on a 2017 RT, the sway bar made a huge difference. I ride 2 up all the time, and I highly recommend it. The install took about 1 hour. just make sure you get the front of the bike up high. I had 16" clearance and it was still a little tight, but manageable.
    Ray
    2017 RT-S
    Bump Skid - Spyderpops
    Wrap - Wrapmyspyder
    swaybar - Bajaron
    Sena 20D & SM10
    3 PC Mesh Zippered Lid Net Set - TricLED
    A arm LED's - Safety LED's - TricLED
    Mirror Sequential turn signals
    Glo-riders
    LED rear turn signals and reverse lights
    Front Grills
    Third Brake light
    Larson Scanner
    Light Up - Sue Hopper
    Nov 2012
    North Las Vegas, NV
    The swaybar is for cornering, the drifting is alignment. Look for a laser alignment shop near you.http://www.spydercomfort.com/dealersmn.htm
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Default Agree...
    get a laser alignment ,check tire pressure and balance. That will help the drift...
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Harrington, Australia
    I had already had a laser alignment and the F3 still had a tendency to wander, especially on cambered country roads. The sway bar is also known a stabiliser bar. Once I installed the Bajaron bar, that tendency to wander disappeared.
    The install is not too time consuming, as long as you can get the front of the Spyder high enough to drop the bar out vertically (something like 22" on the F3).
    HeliBars Handlebars
    Kenda Kanine rear.
    Mar 2013
    Oz
    All above are right I reckon
    in order of priority
    1 is check tyre pressures. Front tyres equal - better ride unless your roads have constant camber!
    Then laser alignment, then sway bar if you like spirited riding
    have fun
