Results 1 to 12 of 12
    Very Active Member JKMSPYDER's Avatar
    Dec 2012
    Murphy, NC
    Default BEST WAY TO REMOVE WHEEL WEIGHTS?
    I received my front wheel balancers from Lamonster Garage yesterday and am anxious to put them on. But I have to remove the weights from the rims first. What is the best way to do that without scratching the rims? A particular solvent maybe? Hammer and chisel?
    2020 F3 Ltd
    Spyderpops Bumpskid
    Spyderpops Brake/Run/Turn Signal LED's
    Lamonster Garage LED Fog Lights and Headlights
    2013 ST-S retired 1/9/16 at 25,061 miles
    2015 F3S sold at 77,565 miles.
    2015 F3-S , BajaRon Plugs Can-Am Red
    Default REMOVAL
    Well you can start by spraying them with WD-40 and let them sit overnight ...... then if you have a piece of hard wood make a chisel and use that to scrape them off ..... If you lay the wheel down and pry the weights up even a little and spray the wd-40 in the space it will work lots better .............. jmho .... Mike
    Active Member Border Rider's Avatar
    Aug 2015
    Derby Line Vermont
    Default Border Rider
    I use a citrus spray for removing gum and glue. It really works well on double sided tape that most wheel weights have.
    Very Active Member Warlock's Avatar
    Oct 2011
    Magnolia, Ms
    Quote Originally Posted by JKMSPYDER View Post
    I used a plastic scraper to remove and then soak them WD40, goop gone, or brake cleaner. I used brake cleaner to remove the glue. But soaking over night would be better.
    David
    Mar 2013
    Like Bluenight911 said WD40 works well, and if you do not want to make a wood scraper you can purchase a plastic one at most places that sell paint.
    2021 Sea To Sky, 2020 RTL
    but our benefits don't?
    2015 F3S , White & Blue
    Sep 2014
    USA
    a plastic scrapper and goo gone works fine..I have used brake cleaner too with a plastic scrapper.
    Default All of the above
    Take your time let the liquid of choice do it's work...
    ​2012 RS sm5
    Jul 2014
    Mint Hill, NC
    Plain old mineral spirits will remove the adhesive. Start with the plastic scraper.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Dec 2012
    Murphy, NC
    ​Thanks for all the input!
    2020 F3 Ltd
    Spyderpops Bumpskid
    Sep 2014
    USA
    hair dryer and a plastic scraper works too.. depending how old the adhesive is, a had dryer may not work in all cases.
    Very Active Member rcturner's Avatar
    Jun 2012
    Fairmont, Minnesota
    This is what I have done to remove tape weights from all of my aluminum wheels. It is slow and a bit of work but, the WD-40 works as a solvent for the adhesive and helps prevent scratches on the rim.
    Dec 2012
    Murphy, NC
    Default Wheel Balancers
    Yesterday I removed the wheel weights by using solvent as others suggested. Installed the Centramatic wheel Balancers on the front wheels and took the Spyder for a spin. I didn't get to ride long as it started raining but I could immediately tell the difference. Very smooth ride. I highly recommend them!
    2020 F3 Ltd
    Spyderpops Bumpskid
