Results 1 to 25 of 31
    New London, WI
    Default High RPM or 2 cylinder vs 3 cylinder
    Hi guys,
    I have a 2012 Spyder with the 2 cylinder engine. Does the high rpm bother anyone else or is it just me? I do a lot of in city driving and rural roads so if I run at the recommended rpm to prevent lugging the thing is always kind of screaming. I have been considering buying a newer Spyder with the 1300 engine. \My question is, is the rpm much lower at lower speeds or is it really noticeable?
    Mar 2012
    NJ
    It's just you....Lol.
    It's a bike engine, and as such runs quicker. It's not a tractor.
    What rpms are you running around town?
    Sent from my Nexus 6 using Tapatalk
    Sep 2016
    clark county indiana
    Default 2012
    have the 2012 s-m 5 { manual clutch } I usually see 4,ooo a little above , { when I am looking at it that is } that is when I am shifting , now at cruse speed I think higher 4,ooo `s I will look again today , but I do not really hear a scream , of the engine it is a higher tone than that of my 2 wheeler ... do you have the automatic ?
    New London, WI
    Default Just me!
    Quote Originally Posted by DrewNJ View Post
    You are right, I think that it is just me and that I need to get used to it. I was a Goldwing rider for many years and was used to that sound. I run at 4000 to 5000 in town. Just seems kind of high to me. Earplugs might help! Thanks for the comment!
    New London, WI
    Default Automatic
    I do have the automatic. Is there a big difference between the 2 cylinder engine and the 3 cylinder? I haven't ridden a 3 yet so will try on on for size as soon as it warms up. I put on 70 miles this spring but it doesn't want to warm up very fast here in Wisconsin. Thanks for the reply.
    Thinks out loud Jeriatric's Avatar
    Apr 2012
    Arrow Here's your answer
    Much cheaper than buying a new Spyder.
    And, I'm not being a wise guy.
    They will, silence your complaint.
    Active Member Dray's Avatar
    Dec 2014
    Graham Tx
    Default High RPM
    Here is a nickels worth of opinion!!
    ACQUIRE AND USE EAR PLUGS!!! The downside of not using ear plugs
    is that you will lose your hearing sooner or later!! Believe me that it is not
    a fun thing as your wife or girlfriend will tell you. I do speak from experience.
    Dray
    Apr 2011
    GREENVILLE, SC
    Default X-COUNTRY
    i've done cross-country rides on both my RS with the V-twin 990, and my F3 with the 3 cyl. 1330, and i'm here to tell you that the 1330 is far more enjoyable than the 990... at 60 mph and above, the 990 engine SCREAMS... and when you're out on the road for 4- 5 weeks, it gets to you.... or at least, it got to me...
    Dan P
    SPYD3R
    Another plus, is the new clutch engagement system that comes with the 6-speed.
    You won't have to worry about burning any clutch plates!
    Out on the highway: you'll be running at least 1,000 rpm lower.
    70mph comes up at less than 4,000 rpm.
    Active Member Large1's Avatar
    Dec 2016
    Boise ID
    Quote Originally Posted by kbruehl View Post
    Hi guys,
    There is a Volume UP button on the left just push it till the engine noise goes away. Problem solved!
    I too just came form a Wing and it took a while to get used to it but I am getting there, It the nature of the beast.
    Dick Harding
    Boise,ID
    2011 Spyder RT SE5 Limited
    Life should not be a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside in a cloud of smoke, thoroughly used up, totally worn out, and loudly proclaiming "Wow! What a Ride!
    Large1 is online now Report Post
    Active Member SteveP's Avatar
    Mar 2016
    Toronto
    Default Soon for me
    Hi guys,
    I really enjoy my 2008 GS , I added the Yoshimura pipe which seems to improve power especially at lower rpm but is a little louder. Yes these engines need to run faster than a lot of bikes I've had , but I drive it how the engine works the best ( like anything I've driven)
    That being said ... Seeing the good reviews of the triple 1330 on here it only makes sense ( to me) that my next Spyder will have that set up , not sure whether F3 or RT , Manuel or auto. ( I've driven the semi auto and not sold yet) . Like some have mentioned , out on the highway I feel the Twin could use another gear almost .
    Default your delimma
    Hi guys,
    I hear you friend ...... I'm now 70 , and have never purchased a new car or truck for me ...... however ( after owning two V-twin spyders - used ) I bought a NEW 1330 RT after one test drive at Spyderfest 2014 and have not regretted it ......... Mike
    New London, WI
    Default Thanks!
    Thanks for all the great comments guys! I guess that I will just have to go and ride a new machine and see for myself if there is much difference.
    I have a 2011 RT and a 2014 RT. So I have one of each engine in the stable.
    The noise difference is noticeable, but not so bad I have to dump the 2011 for a three cylinder.
    There are advantages to each flavor. If you have not tried a three cylinder. The answer is simple. Go take a test drive and see what the differences are for you.
    And, if to loud for you, the earplugs do work and will save you about $15K.
    Very Active Member JerryB's Avatar
    May 2014
    Beaverton, Oregon
    Hi kbruehl,
    Re: Does the high rpm bother anyone else or is it just me?
    Three years ago I bought my '08 GS/SE-5. I too could not get used to the high RPM issue; at first.
    I had been lurking this forum for a few months & it finally sunk in to keep her up high. I am now used to it & really no longer think about it.
    In 1961, while in the Air Force, I got transferred from Edwards AFB to RAF Sculthorpe. At Edwards I was in a room by myself. At Sculthorpe I was in a open bay barracks with 9 other guys. Talk about noise all thru the nite. I finally got used to it & then slept like the proverbial baby. You too can get used to the high RPM's.
    Jerry Baumchen
    'I'll never forget what's her name.'
    'Things are more like they are now than they ever have been before.' Dwight Eisenhower
    2008 GS SE-5
    Linden, CA
    Welcome to the club.... the new eng. is much better and runs at lower RPM
    Hi guys,
    Active Member Border Rider's Avatar
    Aug 2015
    Derby Line Vermont
    Default Border Rider
    I started with a 2011 RT, loved the low end torque and the sound. Rode a 2014 Rt, sounded like a sewing machine idling and an
    outboard when getting on it. I have since bought a 2016 RT and like it but it does't sound like a bike. Miss the roar when I cranked
    on that 998.
    Mar 2012
    NJ
    Acceptable RPM levels is a personal preference. Lower isn't always better....Just different. 4-5k is not screaming...Not even close. Remember that the v990 twin is the F1 of the Spyder lineup and designed to run vs the 1330 that is more in tune with a minivan....😂😂
    Remember that the v990 twin is the F1 of the Spyder lineup and designed to run vs the 1330 that is more in tune with a minivan....����
    Mar 2012
    NJ
    I figured you'd like that one! 😁
    Apr 2016
    Pearl, MS
    After riding a 2014 Road King I made the switch to a new 2016 RT +. My wife had a 2013 RT+ and we decided it was time for a new ride. The difference between the 2 Spyders is very noticeable and after 500 miles I am glad I made the change. It has more power and less noise.
    Sent from my iPhone using Tapatalk Pro
    That was cute!
    ...But having ridden both versions of the 998, and then the 1330: there's no doubt which one is designed as an engine for a touring machine... which is exactly what I was looking for!
    Aug 2012
    CO
    Default Depends on your perspective
    If you're coming to a Spyder from Harley V twins, the 990's sweet spot around 5000rpm might seem a bit frantic. OTOH, if you're coming from sport bikes, like me, 5000rpm seems like it's just idling along.
    JLohPhotos
    2008 GS , Millennium Yellow
    Sep 2016
    Default todays ride continued
    I did go for that ride ,like I mentioned in the reply above , and watched the r-p-m`s ,just riding around the back roads , ---30 to 45 miles per hour , r-p-m were at 3000 too 3800 thousand mark , up and down hills , did not rump on it , just let her do her thing , with 2 riders ... went on a ride up a steep incline , had too hit the 1st gear , went too 3800 4000 reves , a little strain with the 2 bodies and steep climb , ----> now on the way down , the down grade , 1st gear high r-p-m`s hit the 4500 too 4800 thousand she did let me know , but that was the only time she hit that high of a reve , rolling down the highway , at 55 m.p.h. 3500 too 3700 that was about the extent of watching both at the same time ...
    Default It's not you....
    Well it is but your not alone. One of the main problems with the big V-twin is it was expected to be as most a low rpm engine. We have had a few that just could not handle a high rpm twin. I love it and would not change to the 1330 triple. I run over 35% of the time between 5 and 8,000 rpms (way over the speed limit when crusing) and would not have it any other way. If you can not get used to it or enjoy it the 1330 is the way to go. It is low rpm torque is there and it has an extra gear to help out...
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
