Results 1 to 11 of 11
    Aug 2015
    Northern California-Sierra Mountains
    Default Just need y or n
    Just need a yes or no. Will a 175/55R15 tire fit on a 2015 F3S
    Aug 2015
    Thanks for the response.
    looking at: Kumho Solus KH 16, Yokohama Avid, Hankook Ventura, ContinentalConfiProContact, and Hannkook Ventus V4, Federal Evo 595(OEM size).
    Sorry have to ask, any thoughts anyone.
    Yes, most probably!
    The reason for the 'most probably' is that there can be some differences in the 'actual sizes' of different brands/types of tires that have exactly the same nominal size printed on the sidewall, but it's not usually a massive variation - altho it has been known to be as much as 18mm in dia &/or width tho, so can definitely be significant but still within the scope of the available space & manageable by the Nanny! But you might hafta physically check or compare just to make sure....
    All that said tho, I know of & have personally witnessed more than one person here in Aus running tires of those makes in 175/55R15's or even 175/60R15's on their early F3's, so it has been done successfully by some. And everyone I know who is running the larger sized tires in those brands is still extremely happy at the better ride, handling, & performance they get from them too!
    Harrington, Australia
    It's impossible to get just a "yes" or "no" on the generalisation of a "175/55 15" for the reasons Peter A has given, Steamer. You need to narrow it down to a couple of brands that you feel fit your requirements, and then ask if people are actually running them and which one they like best. That will avoid the disappointment of buying a tyre, having it fitted, and then finding it doesn't fit under the guards.
    HeliBars Handlebars
    Kenda Kanine rear.
    Houston
    I can tell you first hand the Yoko 175/55-15 is a perfect fit.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Active Member papanorm's Avatar
    Aug 2016
    central texas
    Just installed 175/55/15 on F3L, no problems with fitment.
    2016 F3L , Big Bike Parts Black
    Active Member Richardv's Avatar
    Oct 2014
    Montreal north shore, QC
    Default YES.....
    Quote Originally Posted by Steamer View Post
    .....just look at my signature. Does fit in both type of fenders. Search my name, already posted on the subject.
    Richard
    * 2012 RS SE5 (hers)
    * 2013 ST SM5 (mine)
    Daughter RSS SE5 2014
    Son in law RSS SM5 2013
    P.S. 3 Kumho AST 225/50R15 and 1 Toyo Proxies 4 225/50R15 rear tires
    2 sets of Kumho 175/55R15 front tires
    1 set of Hankook V4
    1 set of Canadian Tire General tire Evertrek RTX in 14" for the 2012 ...
    Apr 2011
    GREENVILLE, SC
    Default YES
    YES
    DAN P
    SPYD3R
    Y ... provisionally...
    The brand of tire may impact the truth of this answer, so look to see what has been proven to fit!
    Aug 2015
    Default 175/55-R15
    Thanks for all your replies. Narrowed it down to the Hankook or Yokohama because of your responses.
    I have stated before and will state again, the knowledge and willingness to share information on this forum is a blessing. I don't need to rely SOLEY on service department recommendations.
    Apr 2012
    Arizona
    richardv.If all fits so well why are they on a trailer? Suppose to ride not carry.
