Results 1 to 6 of 6
    Very Active Member dpetrick's Avatar
    Nov 2016
    Spirit Lake Iowa
    Default OEM front pegs for 2009 RS
    I am looking for a set of OEM front pegs for my 2009 Spyder RS SE5. Does anyone have a set laying around, that they would like to sell?
    Thanks,
    Dave
    David Petrick
    Certified Professional Photographer
    2020 Limited Dark , Magma Red Black
    Very Active Member SPYD3R's Avatar
    Apr 2011
    GREENVILLE, SC
    Default NO
    NO SUCH ANIMAL exist......
    you'll need to do a DIY if you want front pegs for your RS.... i know, i also wanted some, but found none, so i made my own......
    i bought a set of OEM pegs ($117), then fabbed the bar, and welded a couple pieces of angle steel to the frame (pic #2 & 3) for the mounting of the bar and rode of into the sun-set... worked perfectly...
    if you aren't handy, have a fab shop weld them up for you... i used 3/4" box tubing... you'll need to buy pins & clips to mount the pegs to the bar if you want them to swing inwards... if not, you can have them in a fixed position with pins & clips...
    good luck...
    Dan P
    SPYD3R
    Very Active Member Warlock's Avatar
    Oct 2011
    Magnolia, Ms
    Quote Originally Posted by dpetrick View Post
    Thanks,
    Dave
    Just took a set off my bike. Let me know.
    David
    Jan 2013
    San Diego area
    Default Pegs
    I have a set I took of my 2011 RT/s I can ship from San Diego
    Loving the RYDE
    Oct 2011
    Magnolia, Ms
    Quote Originally Posted by bzbaeren View Post
    I don't think the RT will fit the RS.
    David
    Nov 2016
    Spirit Lake Iowa
    Default Pegs
    Found some. Thanks Warlock
    David Petrick
