Results 1 to 13 of 13
    Mar 2017
    carlsbad NM
    Default Frount trunk wont open
    2012 Rt limited , my front
    Trunk will not open,i can hear the solenoid click
    And key turns easy but trunk doest move. I can grab it and pull up and it will pop up about a 1/4
    Inch.it will do this even if i dont hit the button oy key!! Any help would be appreciated
    Very Active Member jtoro1's Avatar
    Feb 2013
    port st lucie fl
    Quote Originally Posted by sjanway View Post
    Use the key press down and turn
    It's just like releasing the seat-lock; only you turn the key in the other direction...
    Vermont
    Quote Originally Posted by jtoro1 View Post
    Deanna
    Gremlin Bell
    SpyderPops Missing Guard Belt
    Ultimate F3 Floorboards
    Sway Bar with Links
    Rolo Laser Alignment
    Half Cover
    Show chrome Trunk Shock
    Mar 2017
    carlsbad NM
    Default Trunk not opening
    I know how the key works but nothing happens,i can hear it try but trunk wont open. Even tryed having someone work the key and or the button while I pulled up on the trunk
    Default HOW TO OPEN IT
    You need something stiff & thin 16 inches long....... a couple of wood blocks 1 inch square put them in socks ..... start on the right side ( as you are sitting on it ) but your not ..... you want to lift up the corner of the frunk as high as you dare and put a block in there to keep it up ...... get the blk plastic cover off or at least up and put another block in there if you can or something that will hold it up ....... have a strong flashlite and shine it in so you can see the latch mechanism in the middle of the FRUNK ...... at the back of it is a release lever ..... push it with your stick or rod or whatever that is 16 inches long ....... the latch will open ....... I did this for Deanna777 ( lady above ) when her Cable broke....... Mike
    Default FAIL -SAFE RELEASE
    I just forwarded you directions on " How to make a hidden release cable " ..........................Mike
    Active Member MDBrion's Avatar
    Feb 2016
    Southern Maryland
    Default That's the way !
    Just cause you got the monkey off your back doesn't
    mean the circus has left town.
    - George Carlin
    Hollywood, Maryland
    2015 F3S, SE-6
    oem backrest, oem saddlebags, F4 Customs windshield, oem fog lights
    2011 RSS, SE-5
    Handlebar Riser, Heat Wraped exhaust, Power ports int./ext., 23" touring windshield, Led brake lighting strips.
    2014 RTL , Black
    Nov 2015
    Piqua Ohio
    Default LOcked frunk
    I sprayed oil on mine when it did that on my 2012 rts . Push lid back down and let it set for awhile and it was ok then . Now i spray it with oil every few months.
    Mar 2017
    carlsbad NM
    The rod trick work perfectly but instead of pushing it I had to pull on the liver from everything else I've looked at mine is a little different but thanks to all your help I have it open now. Looks like it's going back to the dealer the problem is the solenoid does not hit the letter correctly therefore not pushing it far enough to open the trunk.i bought a extended warranty, its a 2012 so factory warranty was up.
    Spyder only had 724 miles on it,still under 1000 only owned it since Saturday
    Northern Kalifornia
    Default I sent you a PM
    I was shown how to get into any RT or RTS frunk, trunk, and bags with out a key. I was told it was a secret and not to tell anyone how to do it unless there was real need. Good luck, hope it works for you.
    You pulled up on the lid; while a friend worked the key and/or button?
    Pushing down on the lid will sometimes take the tension off of it, and allow it to unlatch..
    Active Member mcalva's Avatar
    Nov 2016
    Viladecans, Barcelona, Catalonia, Spain
    I don't know if that will be useful in this case: http://www.spyderlovers.com/forums/s...ont+trunk+open
    2018 F3 Ltd. , Black/Dark
