Damn battery bolt kit
Can anyone tell me what size bolt is used on the f3 battery? I dropped it in the battery well and of course it friggin disappeared into the nether. Ive looked online and couldn't seem to find the actual size of the bolt and the Can am site was not help. Thanks.
If you are talking about the bolt that attaches the cable to the battery you can probably get one from any motor cycle dealership they should have one off of an old battery.
Well....
Looks to be 6mmx1.25 but the length may vary. 3/4" check to make sure it does not bottom out or your connections will be loose...
Gene and Ilana De Laney
Mt. Helix, California
2012 RS sm5
Is the negative bolt the same size as the positive?
Yes.
2021 Sea To Sky, 2020 RTL
but our benefits don't?
While it is probably easier to just get a new bolt, if you want to find the old one, look in the dead space between the factory skid plate and the bottom of the air scoop chamber you see through the front grill. You have to remove the grill and you may be able to flex the plastic enough to shine a light in the dead space.
H2O
Did the same thing!
Amazon to the rescue :
Yuasa Battery Bolts - 5 x 14mm 479102 https://www.amazon.com/dp/B000WJJG9A..._WpOTfAccM6tbx
Most bike shops have tons of them laying around. I have a drawer full of battery hardware somewhere in my shop........I used to know where it was but its been years since I worked in the service department
Reason: cant spell
SpyderLovers Sponsor
Bolt
Take the other one out, go to hardware store. Buy 2 more just like it! Install the new, have the old as a spare. Done!
or, ride up to Las Vegas. I have several! I'm just not home. Spyders in the Bayou! Home the 5th of April.
Joe Meyer
