Results 1 to 19 of 19
    Apr 2015
    Green Bay, WI
    Default How to break in a new motorcycle engine
    Default Conservatively agree...
    The engines are tested and if they did blow then they were good to go. I have always broken them in as I will ryde them with the exception of hold any speed or RPM for extended periods. I have never had a issue with any motor I have done this break-in process with...
    ​2012 RS sm5
    Very Active Member Firefly's Avatar
    Feb 2009
    Ceresco, Michigan
    http://mototuneusa.com/break_in_secrets.htm
    Basically beat the crap out it...
    I ride them hard right out of the gate.. never had an engine problem.
    Spyder #1 - 2008 GS SM5 Premier Edition #1977. RIP after 80,000 miles.
    Spyder #2 - 2012 RT SM5. Traded in after 24,000 miles.
    Spyder #3 - 2015 F3 SM6. Put 13,000 miles on and sold it.
    Spyder #4 - 2017 F3 SM6. Too good of a deal to pass up!
    Devil's Advocate here...
    I tend to try and follow what is in the owner's manual, for something like this.
    They designed it, and are giving you instructions that will HOPEFULLY result in fewer problems "down the road".
    Feb 2009
    Ceresco, Michigan
    Meh... damn engineers don't know nothing.
    Very Active Member Sam Mac's Avatar
    Dec 2015
    Galax VA
    Guy that used to build my race engines told me to take it and run it, after the dyno session it was broken in.
    Conservative here the first five hundred miles or so. No redline. Vary the engine speeds, use the proper gear range. Easy on the brakes at first.
    Never had an engine problem either. Covers five spyders and over 130,000 total miles.
    Aug 2016
    pahrump. NV
    Default New RTL interstate break in
    Flying in from Vegas to Dallas tomorrow morning to pick up my new Spyder at Louis Powersports in Greenville, TX about 2pm If you see me hitching on interstate 30....Please pick me up.
    I have never done a break in before on 1300 miles of interstate to Pahrump, NV.
    I have had other 3 wheelers before , riding about 150,000 miles. Been riding for about 51 yrs with a total of 1,660,000 miles or close to it.....excited about getting my new Spyder. The thrill just never goes away. Hope to see you on the road
    hisst
    If you are burning gas and killin bugs you must be havin a good time
    Quote Originally Posted by Firefly View Post
    I think to think of all the money that they wasted on their educations...
    But I suppose that the same thing could be said about Print Shop Owners, and Insurance Brokers also...
    Active Member duke50's Avatar
    May 2014
    IL
    [QUOTE=Firefly;1237737]http://mototuneusa.com/break_in_secrets.htm
    I ride them hard right out of the gate.. never had an engine problem.[/QU
    Im sorry but I totally disagree with you on this. Im sure there are other folks out there that think like you do,thats why I would never buy a used Motorcycle
    Apr 2015
    Green Bay, WI
    Angry
    So Bob--do you have a riding lawn mower? I could just picture someone mowing their lawn with the rotary blades at 50% of rpm on their new riding mower---what's the difference anyway--my riding mower is 18 yrs old dual cyl. Only problem I've ever had was with ethanol fuel destroying the vacuum operated diaphragm for the fuel pump. In the end I imagine it really doesn't matter if someone babies their engine or runs it hard. I agree with the guy that has his race engine dyno'd to max rpm after rebuild. NOS & turbo boost can be engine eaters. If someone designs a turbo for the Spyder they best keep the boost under 7 psi because the stock parts--rods-pistons--valve can't handle the extra pressure. Kinda like the guy that changes oil every 3,000 miles--doesn't hurt anything except financial cost.
    Messenger under hostile fire. I'm running
    Darrell
    Quote Originally Posted by Wildrice View Post
    So Bob--do you have a riding lawn mower? I could just picture someone mowing their lawn with the rotary blades at 50% of rpm on their new riding mower---what's the difference anyway--my riding mower is 18 yrs old dual cyl.Messenger under hostile fire. I'm runningDarrell
    Only 18, huh... My last mower ran good for 32 years...
    1983 Ariens HT-16
    Since mowers aren't really meant for partial throttle operation: I ran it through a half-dozen heat cycles, and some light throttle work (towing a brush trailer around...), before firing up the blades in a serious fashion.
    I did the same thing with our new one also!
    2015 Husqvarna (22 Hp. Twin-cylinder Kawasaki engine, and a 46" deck)
    Never have had a lick of trouble with the engines... the mower decks have been fun though!
    Apr 2015
    Green Bay, WI
    1983 Ariens HT-16
    Yeah--the decks & the steering--I wish I was a welder...
    Very Active Member one2doo's Avatar
    Oct 2007
    Johnson City TN
    Same one I use seat the rings.
    Feb 2009
    Ceresco, Michigan
    [QUOTE=duke50;1237982]
    If you read through the link you'll understand how seating the rings using back pressure is a good thing. The worst thing you can do is baby it and run at constant speeds.
    I had almost 80,000 miles on my 2008 GS and the engine was as strong as ever.
    Active Member LateLifeCrisis's Avatar
    Oct 2016
    Maryland
    Quote Originally Posted by Hisst View Post
    hisst
    Congratulations on the new Spyder ~ ~ Enjoy the ryde and good luck on the trip home!!
    He's on his RT She's on her F3
    And the Keys to a Happy Marriage: Separate
    Bathrooms, Individual Remote TV Clickers, and
    His and Her Spyders.
    "If there are no dogs in heaven, then when I die,
    I want to go where they went." ~ ~ Will Rogers
    "Never in the field of human conflict was so much owed by so many to so few."
    ~ ~ Winston Churchill in his tribute to the RAF.
    "I'd like to know why well-educated idiots keep apologizing for lazy and complaining
    people who think the world owes them a living." ~ ~ John Wayne
    GOS 3799
    Sep 2012
    Junction City, KS, USA
    hisst
    Quote Originally Posted by LateLifeCrisis View Post
    +1!!
    Don't forget to post a pic when you get it! And if you break down on the way home, post a pic of that, too!
    PrairieSpyder (Patti)
    Sep 2012
    Interesting article. I don't have the mechanical experience or knowledge to address the debate going on here, but so far I haven't had any problems. But then, I've traded in every two years so far!! I think I'll keep my current ryde for longer, though. I now have about 12k miles. I sure hope I did it right.
    Apr 2015
    Green Bay, WI
    [QUOTE=Firefly;1238260]
    Quote Originally Posted by duke50 View Post
    I agree with you 100%. We need to make sure a few of the other's understand that we are talking about the engine--not the paint job--baby the paint job :-)
