BRP idler
I have a BRP idler that I don't need. Only used for a few hundred miles. Just didn't work well with my older style outer ribbed drive belt. Make me an offer....
2010 RT Audio and Convience SE5, wider vented windshield, XM radio, digital voltmeter, K&N filter, LED turn signal strips, ISCI floorboards, Lamonster LED Headlights and Fogs, Two Bros Black series
Does it have doc Humphrey extender on it . Will it fit 2015 RT-S. If yes I will give 25.00 for it.
I have the adapter kit but i need to remove it from the bike. I pulled the idler off in hopes of possibly trying a rubber type roller but never got around to looking for one.
I do not think there is a rubber wheel. The heat would burn it up. Let me know.
Don't think I could do $25. Got $100 in both pieces together. I can do $50
I will pass and get doc Humphreys.
