Results 1 to 4 of 4
    Active Member Dray's Avatar
    Dec 2014
    Graham Tx
    Default 2017 Limited Wire Color Codes
    Does anyone know the wire color codes for brake/running and turn signal
    wires. I need to add a few lights to my new scoot. Any and all help would be
    greatly appreciated.
    Dray
    Default Try this....
    If your going to jump into the harness download a shop manual. This will save you a lot of headaches... other wise you can double check colors at the bulb connection...
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Dec 2014
    Graham Tx
    Default color codes
    I have down loaded a shop manual but can not enlarge it
    enough to read.
    Dray
    Dec 2014
    Graham Tx
    Default Wire Color Codes
    You know it is amazing how much better things work when you slow
    your brain down and actually read the notes and directions!!
    Dray
