Results 1 to 4 of 4
    Mar 2017
    atlanta
    Default swing arm switch
    Do you have to disconnect swing arm switch when you jack up the back to get tire off ground?
    Active Member Doc - Riverside's Avatar
    Jan 2010
    USA Folkston,Ga
    Quote Originally Posted by wing in atlanta View Post
    As long as you Do Not remove the bolt from the rear shock you can jack it up to get the rear tire off the ground.
    Default Well....
    as long as we are talking about the arm connected to the swing arm, then as stated above if you diconnect the shock then disconnect the control arm as well...that one controls the shock leveling on some of the RT models....
    ​2012 RS sm5
    Mar 2017
    atlanta
    Thanks for the information. Exactly what I was needing.
