Results 1 to 14 of 14
    Jun 2014
    Lowrys SC
    Default K&N filter for RT's with 998
    I have a K&N air filter that I bought from Bajaron, excellent condition, only used for 200 miles before taking out. Make me an offer or maybe you have something to trade of equal value.
    2010 RT Audio and Convience SE5, wider vented windshield, XM radio, digital voltmeter, K&N filter, LED turn signal strips, ISCI floorboards, Lamonster LED Headlights and Fogs, Two Bros Black series
    Apr 2016
    St Thomas, Ontario, Canada
    If you don't me asking, why did you decide to remove the K&N filter ??
    Quote Originally Posted by jroberts650 View Post
    Jun 2014
    Lowrys SC
    Dealer said that's what caused my throttle body issue. Had to have it replaced so if I want them to warranty the new TB I had to replace with a OEM filter.
    Nov 2013
    Central Texas
    That sounds like a load of c**p to me. More like "I don't know what the problem is, so I'll just make something up". I have been running K&N filters in my cars for decades with no problems whatsoever. Find another dealer.
    Jul 2014
    Mint Hill, NC
    I'm not as polite as oldguy. Dealer is full of ! OTOH, under the Magnuson Moss Warranty Act, BRP would have to prove the K&N actually caused the throttle body failure which, in all probability it did not, given the known problem with the TBs. Question comes down to how deep your pockets are if you wanted to fight such a corporate claim. Best course of action is find a new dealer.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Jun 2014
    Lowrys SC
    Quote Originally Posted by oldguyinCT View Post
    I know, I know, BRP covered the replacement of the TB and the dealer covered the labor being over a year out of warranty. So basically they put it to me this way "If you want us to cover this problem if it arises again, you need to replace with an OEM filter". I can't complain too much because in no way did I want to pay for the part of labor.
    Jun 2014
    Lowrys SC
    I agree but I have found another dealer. They're a little farther away but less traffic to deal with. But the case was documented with BRP so I don't want to have to pay either way. It took a little work to get them to cover any of the work so I can't be too pushy.
    Aug 2007
    Greeneville, TN
    Wow! What will they come up with next!?
    My DPS went out and the dealership told me it was because I had installed an aftermarket cruise control unit! Seriously! I told them to go back and think up something a bit more plausible. Next they'll be saying your horn quit because you installed an aftermarket rear tire!
    Very Active Member M109Dreamer's Avatar
    Mar 2011
    Jackson, MS
    This story is as bad as running car tires, nonBRP oil, and now K&N air filter. Would love to hear them try and explain how the K&N air filter did this?
    Sent from my SAMSUNG-SM-G920A using Tapatalk
    2007 M109R LE - To many MODS to list. Its cheaper that way!!!
    Jun 2014
    Lowrys SC
    Quote Originally Posted by M109Dreamer View Post
    I asked for an explanantion and this is what was told, " The K&N filter has oil which gunks up on the throttle body shaft and causes them to bind therefore causing the throttle body code". They could have cleaned it but BRP suggested a replacement since others have had that problem on the older models.
    I agree is horse crap but I dont want to pay that $1300 if it happens again.
    Mar 2011
    Jackson, MS
    Yeah I feel for you.
    Aug 2007
    Greeneville, TN
    So, if your throttle body goes bad again, put in an OEM filter and take it in for service that way.
    The K&N does use an oil attractant for dirt particles. But it stays on the filter. It doesn't migrate to the throttle body. And if it did, it would be such a small amount I can't see it creating any issues. What about the crank case ventilation circuit that runs crank case gases into the throttle body?
    Mar 2011
    Jackson, MS
    I have heard of car dealerships claiming the same thing with cars and the map sensors getting coated with oil. First I have heard of a MC shop claiming that.
    Default K & n FILTER BULL SH*T
    If this is BRP's claim ........ Then why hasn't the OIL that practically SPEWS from the Breather into the AIR-BOX caused them to FAIL .......... Bet they don't have an answer for that ....... what a crock .... Mike
