Page 4 of 4 FirstFirst 1234
Results 76 to 91 of 91
  1. #76
    I've been doing some research on Kenda tires, & it seems they CAN build pretty good tires! SmartCars here in Aust run them, & their tires not only look better, they rarely seem to have any of the issues we have with tires! Kenda make bicycle tires & tubes, many riders swear by them as 'the best' tires & tubes available; & they make Fork Lift & Loader tires, very few problems reported there?! There's more examples like that out there, & it seems they get the bulk of the good stuff, while BRP & the Spyders we are buying more often get the crap & even potentially dangerous stuff?!?
  2. #77
    One of the best sledge hammers, 1.5 kg, I've ever seen or owned is the one I bought in Finland in 1989. It was made in China!
  3. #78
    ....As far as the Centramatic balancers are concerned I have a hard time in my mind seeing, other than from the standpoint of convenience and ease of use, how they can be better than a proper spin balance. If experience overall shows that a good spin balance is needed 3 or 4 times during the wear life of a good tire because tire wear significantly affects balance, then I'll accept that the Centramatics would be a good investment.
    It's actually the USE of the vehicle & driving on the road rather than tire wear per se that leads car & tire manufacturers to recommend that you get your wheel alignment & tire balancing done regularly throughout the life of your tires! Here in Aust, the recommendation is currently to get a wheel alignment & balance done whenever you fit new tires & then get them checked at least every 6 months or 10,000km; & also to always get them checked after a significant impact on a kerb or pothole etc - if an impact jars you so much that you hurt, even if only for an instant, then you should get your wheel alignment & tire balances checked!!
    Here, we can access tire life warranties of up to 100,000km IF we comply with that regular balance & wheel alignment check regime, usually for a very reasonable cost - for the wheels on my 4WD's it's only $50 to check the balance on all the wheels (inc both spares) plus doing the w/align, so over the life of a set of 6 tires it's LESS than the cost of just one new tire!! And if you run Centramatics or similar, the balance requirement is waived & it's significantly cheaper for the w/a check alone!! I'd even go so far as to suggest that most Heavy Trucks & commercial vehicles that have a good safety & roadworthiness record here in Aus either already use Centramatics or similar devices, or they get their tires regularly balanced & their wheel alignments checked.... Just Sayin'
  4. #79
    Houston
    So JC, just to clarify.......in your opinion, with my fairly new(1500km), balanced front Kuhmos, would I be better off removing the balance weights from the wheels or not?
    My
    professional opinion is if the wheel/tire is properly balanced, there is no need to remove the weights and unbalance the assembly when installing the centramatics. When you go to install new tires, remove the old tire, all the old weights and mount the new tire with the yellow dot aligned with the valve stem and install with the centramatic.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
  5. #80
    Makes sense. That's one of those maintenance admonitions I've read and heard many times, and almost as often as not, ignored. Shame on me, right?
  6. #81
    Houston
    Not sure why you say I feel otherwise. Sadly, what we have here is a difference of opinion as to what constitutes a defective tire. .
    Sorry
    for my failure to communicate. I think you got though anyway. We feel the out of balance and out of round Kendas are defective. You seem to agree with that. BRP does not. I do not think its right, I also do not think I can do a darn thing to change BRPs mind. BUT I can have great tires on my and my customers bikes that do not have these problems.
  7. #82
    .... Shame on me, right?
    Absolutely!
  8. #83
    Jun 2014
    ny
    kenda does make some good tires, truck & trailer tires. but i hear a lot of complaints about them on here & on the
    indian forum. when i installed some new kenda's for a member here i did see problems in them when balancing & 1 could not
    be balanced at all. the more i see & hear of kenda tires for bikes the more i feel i will change them when mine are low, i think
    i will be going with vredstein. i have not had problems with mine & i have 9k on them, i don't do a lot of mileage so i will be
    changing them because of age next year.
  9. #84
    Jul 2016
    cascade locks, oregon
    I installed the yokohama tire at discount tire for 8.00 and removed 12 of those sticky weights of of the rim. I put the centramatic on and it is smooth as I can tell at 24psi. Was I supposed to leave the 12 weights on there? It has no bounce or anything. Wanted the hydroedge, but discontinued.
  10. #85
    Sep 2014
    USA
    from what I understand the weights should be left on as you have must have got lucky because you are saying the front dont shake while driving
  11. #86
    Houston
    Quote Originally Posted by tim1 View Post
    The weights were for the Kenda. I would have suggested balancing the new tire prior to mounting the wheel on the bike but yours turned out fine. If its smooth, leave it be.
  12. #87
    Aug 2013
    Never seen these before, what makes them worth $100 ea?
    Ive had my Spyder 5 years, still have factory front tires, on my second rear tire.
    Never had an unbalanced feeling, nor unusual tire wear since I originally laser aligned my bike.
    Just wondering how this is worth it over balancing? Can do a lot of balancing for $300. Lol
  13. #88
    Harrington, Australia
    Quote Originally Posted by SNOOPY View Post
    You sure CAN do a lot of balancing of OEM tyres for $300, Snoopy, but for those of us who, for whatever reason, have moved to 3rd party car tyres and don’t have a Can Am dealer to fit them, balancing can present issues for the tyre shops. The Centramatics are a one off purchase, address the issues where tyre shops may damage your hub if they aren’t careful balancing, and for me, provide excellent value for money.
    HeliBars Handlebars
    Kenda Kanine rear.
  14. #89
    Aug 2013
    Ah, so an issue with balancing or an issue w non-motorcycle tires.
    I couldn’t find a tire shop who could mount my new rear tire and had to take it to a BRP dealer, who seemed to balance it fine.
    Maybe fronts would be an issue on mine, don’t know yet.
  15. #90
    Yeah, the tyre shop was worried about their balancer damaging the integrated F3 hub, Snoopy.
    My dealer (200km away) would not replace the Kenda with a Kuhmo, so I had to do it myself. I could have had the rear balanced at a local motorbike shop, but their balancer was broken at the time, and they were waiting for a part from overseas, so I left the rear unbalanced and went with Lamonster’s Centramatics.....figured I may as well go with them on all 3 wheels, even though the tyre shop was able to balance the fronts safely. Overkill perhaps, but hey
    HeliBars Handlebars
    Kenda Kanine rear.
  16. #91
    Aug 2013
    Ok, cool. Thanks for the thoughts.
