Results 1 to 4 of 4
Hybrid View
    Mar 2017
    Massillon ohio
    Default Ignition switch replacement
    I need to replace ignition switch does anybody know how involved that is it won't shut off and the key came out but you can't get the key back in
    2014 ST Limited
    Jul 2011
    Mitchell, Ontario, Canada
    From the online parts catalog. Part # 710003598 Ignition Switch $259.99 USD
    There are detailed instructions in the service manual on how to remove and replace it. So I would recommend getting a service manual before tackling it yourself. It does not look too bad if you have good mechanical skills.
    Even if you replace the ignition switch yourself. You would still need to have it connected to BUDS (dealer) to have the new keys accepted by the ECM.
    Very Active Member PaladinLV's Avatar
    Feb 2015
    Las Vegas
    If there is a problem. it's be covered under extended warranty.
    AJ
    Quote Originally Posted by edgexsnoglobe View Post
    2014 ST Limited
    2014 RT-S
    Akrapovic Exhaust & Cat Bypass
    Bajaron Sway Bar w/links / Sena SM-10/Garmin 660
    Comfort Seat w Adjustable Backrest
    Decals by Purple Harley / Magic Strobe
    Kuryakyn Black Widow Pegs Rivco Highway Brackets
    Rivco Trunk Mounted Double Flag Holder
    FOBO / Spyder Cuff / XM Radio w MC Antenna
    2014 RT/S , Black
    Mar 2017
    Massillon ohio
    I got The ignition switch Took just a couple of hours to pull the old one out and put the new one in and trailer going over to my dealer and for 80 bucks he did the rest actually not a bad job
