Results 1 to 12 of 12
    Sep 2016
    surfside beach
    Default EXTENDED WARRANTY
    WHERE CAN I GRT OR DOES ANYBOUDY KNOW ANY CO THAT WILL COVER MY CAN-AM AFTER THE EXTENDED WARRANTY WOULD THINK SOME ONE WOULD BUT WILL BRP TAKE IT THANKS ELECTRICMAN
    Jun 2010
    Las Vegas
    Are you talking about something after year 5? You get two years factory and Best can go up to three more.
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    Sep 2016
    surfside beach
    MY EXTENDED WARRANTY WAS UP ON MARCH 14 BRP SAID I COULD NOT DO BECAUSE OF IT AGE ITS A 2011 CAN-AM SPYDER RT BUT IT ONLY HAS 3700 MILE ON IT WHAT TO DO?????
    Dec 2015
    South Carolina
    Default Extended warranty question.
    Same question. I have a 2012 RT with low milage. My Best extended warranty is over later this year, and I would like to extend for a couple more years.
    Very Active Member jtoro1's Avatar
    Feb 2013
    port st lucie fl
    Quote Originally Posted by electricman View Post
    Get an aftermarket warranty they're just as good best is not even part of BRP it's a the aftermarket too. There is other brands out there. Call Pit Bull they got good deals
    Feb 2012
    Spring City,Utah
    Zurich has a very good extended warranty that I put on my 2012 RTL.
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Sep 2014
    East Texas
    Smile Screw the extended warranty
    Forget the extended warranty and buy a BRP manual. This will give you step by step instructions to fix most things. Yes, you will have to spend a little on tools.
    I had a water pump start leaking on my 2010 RT. I took it all the way down and removed the clutch cover so the old water pump could be pressed out and the new water pump could be pressed in. I did have to buy the special tool to press the water pump in with but that's ok. I learned a lot along the way and I know that bolts were torqued, not put on with whatever torque was set in a drill/driver. Praise God, everything has been dry for the last two years.
    Mar 2010
    Indianapolis, IN
    Post Yes, you can get an extended warranty.
    The 3 year BRP extended warranty on my '12 RTS expired this month. After doing some checking and calling around I ended up purchasing a 3 year Rider's Advantage Service Agreement offered by Century Automotive Service Corp. This MUST be purchased through a dealer. The best deal I was able to find was at Pitbull Powersports. They were very helpful in explaining the program and we handled everything over the phone. Give them a call.
    Sep 2016
    surfside beach
    Default extended warranty inc. co.
    Quote Originally Posted by funon3 View Post
    if you can get back to me if you have any phone on inc. co. # i would be very thankfull
    Sep 2016
    surfside beach
    thanks
    Jun 2010
    Las Vegas
    In my world a Service Agreement and an extended warranty are two different things. With a Service Agreement you get X number of services for a set price and the extended warranty covers certain repairs to covered items that quit working. So a Service Agreement may not cover something that goes wrong or breaks on your Spyder but they likely cover things like scheduled maintenance. Really do your research before you purchase anything as you may never get your money's worth out of your investment.
    2010 RT- 622
    Mar 2010
    Indianapolis, IN
    Default Suggest calling Pitbull.
    I would suggest calling Pitbull Powersports. You don't have to buy from them but they sent me all the details about the plan via e-mail that explained everything very well. Any dealer can sell the plan. I bought from Pitbull because they had the best price for the plan I wanted. You can reach them at 417-863-1418 and tell them you want info in the Riders Advantage Service Agreement. Hope this helps.
