Results 1 to 16 of 16
    Active Member papanorm's Avatar
    Aug 2016
    central texas
    Default Jacking front for a tyre change
    I'd like to know how to lift the front to remove both tyres. I have floor jacks that i can use either under A arms or center frame. I am dropping the Kenda's and going with Continental contiprocontact 175/55/15 and excited about the handling improvement
    2016 F3L , Big Bike Parts Black
    Default Depends....
    Under the A arms if doing one at a time, under the main frame (front) to do both. A stands to support your work...
    Aug 2016
    central texas
    I have two floor jacks only and will be removing both wheels at the same time. I suspect with that equipment I should be able to have the machine more stable with jacking each side up.
    Are there any of those places around that allow you to rent tools for the day?
    Something like "Rent-A-Center"?
    It's probably better to lift the bike from it's belly, and just use your jacks under the A-arms to steady it a bit...
    Aug 2016
    central texas
    Thanks y'all - I'll check it out
    Very Active Member AeroPilot's Avatar
    Nov 2012
    Pueblo Colorado
    Default Put a piece of wood or 3/4 " plywood on the jack plate and under the A-Arm,
    Quote Originally Posted by papanorm View Post
    FIRST: Make sure parking brake is set. NEXT: Break loose lug nuts while still on the ground. A 13/16" thin wall spark plug socket works wonderfully.
    Then jack it up one side at a time until the tire is free, and make sure jacks are stable. Support with blocks if leaving for a time.
    Remove lug nuts and wheels and take them to have the tires swapped out. Take a look at the brake pads if you're over 10,000 miles. My fronts lasted over 20,000 miles.
    Inspect / Clean / replace wheels and lightly seat lugs. Return to the ground and torque evenly to 75-80 ft/lbs
    2015 RT , OEM Black Gloss
    Aug 2016
    central texas
    That sounds like the best way to go for what tools I have. I know that some hydraulic jacks don't hold after a while and blocks may be needed. I have jack stands as well. but don't need to lift too high for this so won't be using them. Appreciate the good advice.
    Oct 2011
    Kalamazoo, Mi
    Default front tyre change
    You'll love those Conti's
    2018 F3-T
    2018 F3-T , Pearl White
    Aug 2016
    central texas
    Quote Originally Posted by IGETAROUND View Post
    What pressure are you running in your Conti's-Thanks
    Harrington, Australia
    Norm, make sure you have a loooong breaker bar. Those wheel nuts are very, very tight the first time you remove them.
    HeliBars Handlebars
    Kenda Kanine rear.
    Oct 2011
    Kalamazoo, Mi
    18psi
    2018 F3-T
    Aug 2016
    central texas
    I remember you saying that when you changed your fronts - just one more challenge
    Lol.......it's not really a challenge once you know about it and realise that you aren't doing something wrong.......it's the rear axle (I know you are doing the fronts) that creates a real problem though. I had to buy a 10' breaker bar, climb to the top of my 18' ladder and jump down very accurately on to the bar to loosen the bolt. I then had to repair all the cracks in my concrete floor from the resultant crater that was left, and explain to the police why the Bureau of Seismology had recorded a force 7 earthquake at my address. But it's alright now !
    I am looking forward to meeting Finless Bob one day, as he managed to remove his axle bolts with a standard spanner. He MUST have 54" biceps
    HeliBars Handlebars
    Kenda Kanine rear.
    Aug 2016
    central texas
    Pete!! You are hilarious and made my day!
    May 2014
    Benson, NY
    I hear that it can be done but I myself could not live without my yellow ATV jack.
    2015 RTS Special Series
    Russell Day Long seat
    F4 Customs windshield
    Sena 20s
    Aug 2016
    central texas
    Follow up
    I invested in the Craftsman aluminum atv/motorcycle jack and am very pleased with the outcome. I took all of the great advice shared and enjoyed a very easy job getting the wheels on and off. I had the tyre shop mount the Conti's in 175/55/15 and brought them back for a non-eventful install.
    The new tyres transformed the bike into a much better, smoother, more delightful handling machine. They are confidence inspiring in the curves and love the result. BTW, the tyre guy said the tyres that came off were crap)
