Page 1 of 2 12 LastLast
Results 1 to 25 of 35
    Active Member Kredab's Avatar
    Oct 2015
    Iowa
    Default Make sure I understand - Radio talk
    Got an MP3 player attached to the female 3.5 audio in the truck, I could only adjust the volume from the handlebars.
    Is there a player that you can attach to that same 3.5 cable that you can totally control from the drivers position, adjust volume, move forward in the song listing, etc,etc ?
    Has anyone put a bluetooth adapter on that 3.5 line and been able to control MP3 player mounted on handle bar?
    Watched Lamonster's video and it says you still need an RT cable to the radio? Plus If that is the route I want to go, is there an MP3 player that doesn't have to be turned on and off?
    2016 RT-S is my weapon of choice
    Thanks, Good Morning from IOWA
    2016 RT-S Pearl White
    BRP Driver Backrest
    Lamonster Spyderdock, (2) Spydercuffs
    Magic Mirror w/Doc Humphreys tethers
    (2) Rokform phone mounts
    FOBO
    SpyderPops Bumpskid,missing belt guard,Rear strobe LEDs
    Lamonster LED headlights & foglights
    Spyder Pockets
    LED front fender kit -running & turn signals
    Custom Back off mudflap
    Vinyl nameplate & 1330 triple decals by New Image Signs
    Custom RLS exhaust
    Hogtunes speakers 5 1/4 front and back
    Memphis Powersports Amp
    Her name is "Purl"
    2016 RT-S , white
    Jun 2014
    Lowrys SC
    Quote Originally Posted by Kredab View Post
    I went to Walmart and picked up a 6' auxiliary cable, plugged into the trunk with adapter, ran wire under panels to handlebars and connected a XM radio. Works great. Not sure if a bluetooth will work being in the trunk, maybe too much obstruction for phones to connect.
    2010 RT Audio and Convience SE5, wider vented windshield, XM radio, digital voltmeter, K&N filter, LED turn signal strips, ISCI floorboards, Lamonster LED Headlights and Fogs, Two Bros Black series
    Jun 2014
    Lowrys SC
    Here's the pic....
    Very Active Member OverHillAndDale's Avatar
    Sep 2014
    United States
    Default Nyrius Bluetooth
    There are several companies that make one of these if you can't find this one:
    https://www.amazon.com/Nyrius-Blueto...rius+bluetooth
    This is a Bluetooth device that fits on the iPod 32 pin connector, but will communicate with any BlueTooth phone. You can control music selection on your phone in front without a physical cable running to the back.
    2020- RT Limited
    Chalk White, Can-Am rear passenger armrests, Comfort Seat, Grip puppies, RAM Cup Holders, Providence RAM Mount
    FOBO2 TPMS
    Aluma MCTXL trailer
    BRP hitch
    Big Bike Parts wiring harness
    Permanent Smile!!!
    Jun 2014
    Lowrys SC
    Quote Originally Posted by OverHillAndDale View Post
    I tried a bluetooth device and connected the same way but my phone wouldn't stay connected due to the obstructions to the trunk (me, passenger, back of seat) So I just ran a cable and no more problems.
    Get yourself an IPod, and plug it into the USB port...
    Jun 2014
    Lowrys SC
    Yeah, Kredab should be able to do that. I forgot about the newer models having extra connections. Us older RT's had to become a little more savvy to have more adaptability, lol. Man I wish mine had been that simple
    Oct 2015
    Iowa
    Thanks Bob, So an ipod plugged into the usb in trunk, you can control from handlebars? volume,move to the next song, etc but only apple products will work on the spyder screen ?
    BRP Driver Backrest
    FOBO
    Spyder Pockets
    Custom RLS exhaust
    Her name is "Purl"
    2016 RT-S , white
    Sep 2014
    United States
    That is correct - I have an iPod Mini in my trunk and I can select songs and playlists, and I can forward to the next or previous song using the handlebar controls.
    2020- RT Limited
    FOBO2 TPMS
    Aluma MCTXL trailer
    BRP hitch
    Permanent Smile!!!
    Sep 2016
    dilworth,minnesota
    hook my Ipod to a usb port in the trunk set the volume put it on shuffle can ride all day and seldom hear the same song twice works great.
    Apr 2015
    Madisionville,KY
    Default Helmet Speakers
    I found the speakers on the RT worthless at speed, I have a Sena S20 communicator and I replaced the stock speaker with
    ASUS XSound 3 High Definition Helmet Speakers
    They are expensive @119.00 but they do the job and the fidelity is pretty dam good.
    Very Active Member SteveLaoyster's Avatar
    Nov 2015
    Myerstown, Pennsylvania
    I'm not sure if I understand. Are you trying to play music differently than you already can? I have the same RTS that you have & just plugging a flash drive formatted in FAT32 will allow you to play anything you have on the drive. Check your owners manual for info on this.
    AKA Jud Smales, Four Year Spyder Ryder!
    "Quando Omni Flunkus, Moritati"
    The Critter 2016 RT-S
    Cat Bypass from Lamonster
    BajaRon Sway Bar
    Hella dual horns with relay
    BRP Hitch with trailer module
    Foam Grips
    Adjustable Air Deflectors
    Driver & Passenger Gel Pads in Seat
    Shorty antenna
    Ultraguard half cover
    Gremlin bell from my son
    Break Stripe Kit from Wrap My Spyder
    2016 RT-S , stock not yet Pearl White
    Oct 2015
    Iowa
    Quote Originally Posted by SteveLaoyster View Post
    I tried a cheap MP3 player into the 3.5 mm plug in the trunk, all I can control is the volume from the drivers seat. What you are saying is that you are plugged into the usb port and you have full control ? so maybe the key is the usb port? I will try plugging flashdrive in to see if I can control from driver seat.......Thanks for the post
    BRP Driver Backrest
    FOBO
    Spyder Pockets
    Custom RLS exhaust
    Her name is "Purl"
    2016 RT-S , white
    Sep 2016
    US. ohio n/e
    I ve got a blue tooth in trunk send my music threw my fon...work grt
    Sent from my LGLS675 using Tapatalk
    Sep 2014
    United States
    A USB flashdrive won't work - the port is designed to work exclusively with the Apple iPod/iPad/iPhone communication protocols. If you use the stereo jack it only receives the analog music signal but there is no mechanism to Next/Previous/Playlist etc. Even on the Apple connector the port won't let you select whether to play a playlist randomly, that has to be selected on the Apple device itself.
    2020- RT Limited
    FOBO2 TPMS
    Aluma MCTXL trailer
    BRP hitch
    Permanent Smile!!!
    Sep 2013
    Houston
    Sorry,
    but wrong information. The OP has a 2016 with USB ports, not the old apple connector. A standard flash drive loaded with MP3 files works great on 2016 and newer RT and F3 models that have factory radios.
    Blue Flame Spyder F3-S
    2015 F3S , Blue Flame
    Sep 2014
    United States
    My apologies - I should have checked my facts first!
    2020- RT Limited
    FOBO2 TPMS
    Aluma MCTXL trailer
    BRP hitch
    Permanent Smile!!!
    Oct 2015
    Iowa
    Thanks everybody, I plugged flash drive in it works great , probably will go with that method for awhile, I'd rather spend money on new farkles instead of an ipod........
    BRP Driver Backrest
    FOBO
    Spyder Pockets
    Custom RLS exhaust
    Her name is "Purl"
    2016 RT-S , white
    A new I-Pod almost qualifies as a farkle...
    ...almost...
    May 2013
    Stanton, ca
    Ipod work the best in my opinion.... You get far more control on the dash and handlebars...
    Bob
    2011 RT-S SM5 - Black
    Sep 2014
    United States
    Agreed
    2020- RT Limited
    FOBO2 TPMS
    Aluma MCTXL trailer
    BRP hitch
    Permanent Smile!!!
    Oct 2015
    Iowa
    Default Baffled
    Ok, for some reason I cannot get the USB to work, it says "no files". If anyone has ideas here I will take them. I have one USB that I bought with a KISS concert on it and that works fine.
    I'm baffled on this one.
    My 20 year old son couldn't figure it out checked format and all.
    Took old iPhone loaded it and I have complete control of it from the handlebars
    BRP Driver Backrest
    FOBO
    Spyder Pockets
    Custom RLS exhaust
    Her name is "Purl"
    2016 RT-S , white
    Idaho
    So are you saying the USB port works and one USB stick works but the other USB stick doesn't? If so, then that of course is more a computer type problem and not a Spyder problem. Time for a hard drive/memory stick diagnostic program like WinHex.
    2014 Copper RTS
    Active Member woodyaa's Avatar
    Mar 2015
    Harvard, Il
    Check re owners manual and see if there a capacity restriction on the flash drive. My car won't accept anything larger than an 8 gb and must be formatted in fat32. I would check it myself but I have a 2015 without USB. Good Luck!
    Oct 2015
    Iowa
    I have one flash drive that I bought at a KISS show of the concert I just seen(cool huh) that flashdrive works perfectly in the Spyder(1gb). I loaded a 4gb flashdrive at home and kept saying "no files" on the screen, I do know that the songs on my made flashdrive were in FAT32, just like on the boughten drive.
    Could it be the size of the drive ? (4gb is small by today standards)
    My music problem is fixed, I used on old iphone 5c loaded it up and we are good to go.....
    BRP Driver Backrest
    FOBO
    Spyder Pockets
    Custom RLS exhaust
    Her name is "Purl"
    2016 RT-S , white
