Results 1 to 15 of 15
    Invalid Emails
    Nov 2014
    USA, FL, Venice
    Default LED reverse lights?
    Nothing showed up on a search. Has anyone converted the white reverse lights to LEDs? I have a 2014 RTL.
    Active Member wd8ajj's Avatar
    Jul 2014
    Las Cruces NM
    I found them at Auto Zone a while ago for my 2014 but at 13.00 each was not worth it. Not sure if they have dropped in the last year. Never followed up on it. Just take the bulb number to them, they will match it up.
    Also try Batteries and Bulbs, they usually can get almost anything.
    Active Member NM Wrench's Avatar
    Apr 2014
    Albuquerque, New Mexico
    Default Yes
    Hi,
    Yes I have changed the reverse and also the turn signal bulbs in addition to the headlights and fogs. So all of mine are now LED's. Mine is also a 14 RT-S
    14 RT-S , Stock Large brake pedal White Pearl
    Active Member ricford's Avatar
    Jun 2015
    Calhoun, La
    Quote Originally Posted by NM Wrench View Post
    Hi,
    What was your source fo purchasing the bulbs? Auto parts house, perhaps?
    Default LED's
    Quote Originally Posted by ricford View Post
    If you can't source them locally ----- E-bay has ......EVERYTHING ................. Mike
    Jun 2015
    Calhoun, La
    Should have asked but forgot. How does one change the bulbs? My guess would be to, DARE I SAY IT, remove tupperware?
    Apr 2014
    Default I got the turn signal bulbs here
    Here is the link I used for the turn signal bulbs https://www.superbrightleds.com/. I got the back up bulbs from a vendor on the home page here.
    Very Active Member SpyderConvert's Avatar
    Jun 2016
    Catonsville, MD
    Default LED Bulbs
    Got mine from PEP Boys (auto supply) locally. You might even try WalMart.
    2015 RTL, BajaRon Swaybar, LaMonster LED Headlights and Foglights, LaMonster Spydercuff, LaMonster LED mirror wrap, Magic Mirrors, HMT Brake Light
    2015 RT Ltd. , $" extension Black
    Active Member Bogie's Avatar
    Feb 2014
    Brown City Michigan
    Another source for LED bulbs is: Superbrightleds.com
    I purchased LEDs for my rear turn signals as well as for all of mr car lights.
    Jun 2015
    Union, Missouri
    If you change your turn signals to LED's does it cause them flash faster, or will they flash at the normal speed?
    Don
    2015 RTSS Limited, red/white, Lamonster NVB highway bars, Ultimate midrider seat with backrest, Show Chrome passenger armrests .................................................. .....
    How about some part numbers for these LED replacements pieces?
    May 2015
    Barryville NY
    Default Bulbs used
    these are the bulbs currently in my 2014 rts. Work fine but have to reset flash rate when done installing.
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    Quote Originally Posted by beast68 View Post
    Jan 2015
    southern WI
    OK, I'll bite......how often do you drive in reverse any distance that you would need to change to LED's? LOL.......just kiddin'....but really....
    2021 RT Limited
    2016 RTS , Pearl White
    I would imagine that being brighter, and using less power; would be the selling points...
