Results 1 to 10 of 10
Thread: 2013 Air Scoops
    Very Active Member 2Paw's Avatar
    Feb 2013
    USA, Texas, Mckinney
    Default 2013 Air Scoops
    I bought a set of the 2013 air scoops for my 2012 and I have a few questions. Of course for the price I paid I did not get any instructions, also they are Black and my RT is blue. I don't really have a heat problem but I thought here in the Texas summer heat I could use all the help I could get.
    My questions:
    1. Would it be best to have them installed by a dealer, or at least have them make any needed cuts?
    2. If I decide to paint them does anybody know what the 2012 blue paint code is or know where to find it?
    3. ?
    Thanks in advance for your thoughts.
    Ed
    They told me not to give up on my dreams, so I went back to sleep.
    Champagne 2017 RTS SE6
    Quantum Blue 2012 RTS-SE5 "Bluebell, Bell for short" - Traded 09/2017
    1. Let the dealer at least make the cuts for you... without instructions: better to let them do the full installation.
    2. The color... They called it "Quantum Blue" You could try looking it up at www.touchupdirect.com
    Very Active Member Devious56's Avatar
    Oct 2015
    N.E. Florida
    If you do a search here on the forum for Doc Riverside, he has a very concise set of instructions for installing the side vents. If you have a hard time with the instructions, you can contact Doc Riverside and he will be happy to answer any questions you might have. We installed the vents on my RT in the garage, and wasn't difficult at all and only took a couple of hours. You can cut the required openings using a coping saw, a dremel tool, or anything in between. If you can't find Doc Riverside, PM me and I will get you contact information.
    David
    How old would you be if you didn't know how old you were?
    Active Member Lobo's Avatar
    May 2016
    Murrels Inlet, South Carolina
    Default Air scoops install
    I installed them myself on my 2012 RT A&C. Not hard. Ditto Doc Riverside's instructions. You can also pull up the BRP detailed instructions for the full 2013 modification install. It goes into detail on other modifications that were needed beyond just the scoops install. Take your time and read the instructions several times. Good luck.
    Sep 2016
    Albuquerque New Mexico
    I installed mine . the only advise I have is on the alignment.
    there is a screw that goes into one of the holes where the vent wing was put that screw in to hold the alignment then mark the other holes some you can mark some you kind of guess at as you'll find out. then you put the unit together and the screws in from the back side.
    mine was a 2014 so I didn't cut anything just used them to cool the glove box so my snickers didn't melt
    Feb 2013
    I just realized I hadn't followed up on this. My scoops are installed, my dealer gave me break on the install he said he could cut the hole for $50 or for another $100 he would do it all, so no brainer as far as I was concerned. I haven't noticed any change in engine temp but the Family Jewel area is certainly much cooler . I left them black on my blue Spyder and they look just fine. So I'm happy with them.
    Ed
    Idaho
    Quote Originally Posted by 2Paw View Post
    Black is the only color they came in. A few have painted them but I don't recall who or what sort of paint they used. My 2013 RT was blue and the black scoops looked quite fine.
    2014 Copper RTS
    Apr 2018
    Webster, NY
    Default Air vents/scoops
    Attached are photos of my install, so far today I finish the other side of the bike. I did left them black, probably will dress with black Kevlar skin. Can’t test them as it is to cold to ride....
    P.s. no instructions, just look at them for a few days and figured it out.. I think it was harder to find the instructions than figuring out the install🤨
    2018 RT , Larger pedal Pearl White
    Sep 2009
    La Valle, WI
    I put these on my previous 2015 RTS. I didn't cut a larger hole. Advice from other members. I just removed the original screen and mounted them. I got plenty of airflow. My glovebox was cool in all high temps. It was an oven before scoops added.
    2018 F3 Limited , Oxford Blue
    Nov 2018
    Claremore, Ok.
    Quote Originally Posted by JP58 View Post
    I didn't cut either. Now I can keep a chocolate bar in the glove box even in summer heat. I did put thin heat shield foil on bottom of lid, though.
    Tag-Along trailer
    7' x 10' Cargo trailer
    Garmin 396 LM GPS
    New Banshee AGM
    M3 TPMS on front tires
    Loose Nut Behind Handlebars
