returnning LED headlights
Well I'm giving up on the LED's I just got the return label so back they go. As I am unable to find a stock Clip Need two to try to modify I do not want to mess up my originals. I will have to wait till someone comes out with a complete kit and step be step instruction. I do not have the tools time or skill for R&D to engineer the required parts to do this job. Another day!!! jtpollock
HALOGEN TO LED SWAP THINGY
Are you saying you need some parts off stock RS headlights to try and mod? Which ones? I'm sure there are a set or two of stock RS lights laying around my shop. Let me know if I can help.
Sent from my Nexus 6 using Tapatalk
The parts would half to be from 2012 rs stock retaining Clip that you put on the back of the stock H7 headlight it has a square hole in the center and as you twist to the right to lock the blub in place it also has some spring tension ( the part only comes as a part of a complete Headlight bucket) jtpollock
Hi jtpollock,
Re: I'm giving up on the LED's
I agree with your decision. I have been doing some looking for LED's for my '08 headlights.
So far no one will tell me without a doubt that 'their' LED's will fit my '08 as a Plug & Play change-out.
One problem, since these models are no longer being produced, there is no real incentive for the supply companies to develop products for them.
Just my $0.02 on this issue,
Jerry Baumchen
'I'll never forget what's her name.'
'Things are more like they are now than they ever have been before.' Dwight Eisenhower
2008 GS SE-5
Originally Posted by JerryB
Hi jtpollock,
Jerry Baumchen
Jerry,
YES there plug and play they just won't stay where you put them with out the retaining spring clip thanks for the $0.02 Keep the rubber side down..... jtpollock
Let me look here in a bit when I get back. I just might have what your looking for.
Are these the clips you need? Pretty sure these are out of a 12' RS. They had HID bulbs in them so they have been notched.
Drew,
yes that is what I am looking for I will be in contact. jtpollock
THANKS AGAIN, got the clips yesterday afternoon now comes the hard part making the clip fit I noticed that there is no index tab at the point
that should be the top anyway the fun begins Lamont sent a link to his post installing HID headlights so I have photos and I will try to take photos
so if anyone else comes to this point they will know what to do. jtpollock
